After working through this I believe I have my answer, but thought I would start a thread for others considering the same dilemma. Even though I searched extensively. I couldn’t find a thread that covered my exact situation, doesn’t mean there isn’t one, I just didn’t find it after looking for months. With the input of the great ones on the Mud forum, maybe some alternative answers can be found.
The back story.
Last year I had the brakes switched over to discs front and back. 60 series knuckles and discs up front and Cadillac Eldorado in the back. It’s been a sweet setup so far. I had been lucky with the vintage alloy wheels that came with the rig in that they cleared the calipers and tie rod ends. But I only had the four and my mismatched spare hit the calipers, not good. Soooo… I decided I needed new feet for the old gal in addition to new shoes.
After researching for months here on Mud and with the various wheel suppliers, I finally pulled the trigger last April on a set of five wheels. I decided that the ProComp 15” Rock Crawler Series 52 Gloss Black Powder Wheel - 52-5883 with 2-1/2” back spacing would do the trick. 4 Wheel Parts seemed to have as good a price as anyone so I ordered through their website.
I had gone into their Compton store several times to talk to the guys and get as much info as I could. They were of limited help as they couldn’t entertain thoughts of making modifications like grinding the calipers a bit for clearance. I was reluctant to use a wheel spacer to achieve my goal.
After 2-1/2 months and many phone calls, I finally got the call that they had arrived in Compton.
When I picked them up yesterday, I ordered up a set of 35” KM2’s to skin them with. They should arrive by next weekend from their Texas warehouse. Should be enough time to see what I have to deal with in getting them on the rig.
I pulled one of the rear tires first to see what I might be up against. OK, so they hit the outside edge of the caliper. I doesn’t look like much, but of course the wheel isn’t seated either. A tiny bit of light sneaking through between the caliper and the wheel.
You can see a bit of scuffing on the lower outside edge where the wheel was making contact.
Out comes the grinder. For the next hour and a half I’m grinding a bit, fitting the wheel seeing where it’s hitting, marking the area, grinding a bit more and repeat. I’m paranoid of taking too much off, I am talking about the integrity of the brakes on my daily driver after all. Finally, I get it down to where it’s clearing the wheel by about .019”. And this is where I am now. It might look like a lot, but there seems to be plenty of meat left on the caliper so I’m not too concerned, yet.
The questions I have now are, is .019” enough clearance? I would feel more comfortable with more, but am a little leery about taking too much off. The outer pads seem to be engaged mechanically rather than hydraulically, but I could be wrong. How much movement is there in the caliper while braking? I’m working solo on this so it’s hard to tell and perhaps there’s more movement when the rig is actually moving. This is stuff I just don’t know and would love to hear some thoughts from the pro’s.
The back story.
When I picked them up yesterday, I ordered up a set of 35” KM2’s to skin them with. They should arrive by next weekend from their Texas warehouse. Should be enough time to see what I have to deal with in getting them on the rig. I pulled one of the rear tires first to see what I might be up against. OK, so they hit the outside edge of the caliper. I doesn’t look like much, but of course the wheel isn’t seated either. A tiny bit of light sneaking through between the caliper and the wheel.
where'd that fluid come from?!? I guess I need to find a junk 60 series caliper and grind it until I do break through or section it. Then I could move forward.
I had more than 1/8” clearance! I double checked with the template I had made from the other side. Right on the money. OK, so what would cause the difference? I thought about the adapter that held the caliper to the axle. Wondering how much wiggle room there was in that mounting. I loosened the bolts on the right side, the one I had ground down first. Gave it a good shove and it slid over a bit!
WooHoo!
Now I have more than 1/8” clearance on both sides in the rear without spacers and feel confident that the calipers are still plenty strong.
