Ratpuke
SILVER Star
- Joined
- Jul 2, 2002
- Threads
- 262
- Messages
- 3,328
I need some help. I normally hang out in the 70 series section and haven't posted in here for a very long time. Turns out it has been a very long time since I've wrenched on one of my 40s... but I'm in the process of getting my BJ42 through an out of province inspection and ready for ACT2010 and I'm in need of some help.
Several years ago I bought an ARB for my BJ42 (semi floater rear). The locker was installed but never hooked up and on the way back from a run the driveshaft blew off and the diff was hooped.
The locker was removed from my 42 and my ex put it into his 87 BJ74 (full floater front). No, I'm not gay and yes, I'm a chick. Last Spring he blew up his front pinion. Upon the demise of our relationship I was blessed with the return of my locker in his broken differential as a parting gift.
So...
Now I'm trying to get my air locker (RD 124 I believe) installed back into the rear axle of my BJ42. We've run into trouble. The set-up diff is in the housing, and the axle stubs and c-clips have been installed, but where do we go from here? Three questions.
1) How is the pinion shaft removed to install the pinion spacer (or spider block)? It does not appear to be a matter of removing a retaining bolt like with the stock diff. Does the circled screw play a role in pin retention or removal?
2) Since the locker was last installed in the front of a different cruiser and my parting gift did not include the ARB spider block/thrust block... can the stock pinion spacer be used in its place? Or will a spider block need to be sourced?
3) Does anyone happen to have a link to a set of proper installation instructions?
A few pics…. Note evidence of the loving modification that occurred when the first pinion gave way.
So...
You never cease to amaze, my friend.
