'72 FJ40 project with 2F -- Will I be able to simply bolt all my 3 speed components (bellhousing, clutch, pressure plate, etc.) to my newly rebuilt 2F? Thanks.
I do have a 4 speed flywheel that appears to be in good shape. Are you saying I can use the 3 speed bell housing with the 4 speed flywheel, disc and pressure plate bolted to my 3 spd tranny? Thanks for providing your direction.
I think you would use the 3 speed disc, as the 4 speed has a different spline count to match the 4 speed transmision.
You can use any flywheel and bellhousing you want, but you have to use the appropriate pressure plate for the flywheel you choose. The 4sp PP won't work with the 3sp flywheel and visa versa.
Not in the USA, not behind the F or 2F....clutch discs, just like transmission input shafts, are splined the same...
The transmission/engine combo that has a different splined input shaft is any transmission behind the b series diesel. They are longer, and have a fine spline.
The gas trucks in the USA all used the same splined clutch disc.
The bellhousings interchange between the 3 spd & 4?![]()
I'll need to look again but, I think the 3 speed flywheel that I have is missing a tooth.
Hillbilly flywheel...cool!
