Lockers??
I have ARB's front and rear, I cant imagine having anything BUT selectible lockers. There are times it is a HUGE benefit to be un-locked such as certin steering manuvers or on icey/slick roads and there are times that only lockers will get you though- Now have the best of both worlds with a selectable. If your already gona spend that much money, save for another month and go all the way!
also use search function, tons of info
just 1 mans thoughts
that suff is all true, but my liking is the Aussie Locker. It's a spider gear type but without the problems of a quick lok that will wear out kinda fast. If you do a search for them I know you'll find good info that's how I found mine...
ps-you can buy 4 Aussies fopr the price of 1 ARB so if price is a factor,also remember you need air lines that I don't know if the come with it or not and the compressor that don't come with it.
Arb's come with switches air lines and vavles.The only thing you need to get separately is onboard air.I have them front and rear and couldn't imagine not having them.One of the best thing I bought:cool:
X3 on the F&R ARBs. Mine are fantastic! I had a rear Detroit Locker in another truck and much prefer the ARB.
Very happy with my ARBs.
I had a Powertrax No-Slip, and while it worked, it seemed a bit slopy, and too harsh on my running gear on the street.
What ever you decide, a locker makes a killer difference. Sooo many people do everything to a rig, but not put a locker in, yet a locker makes the most difference.
I'm running the Aussie locker in the rear of my 55.
A bit noisey on occasion but it make a difference when wheeling.
I guess if I had the money, ARB's front and year.
I used a locker all the time in high school, very handy for storing books and your coat and stuff.
...next to driver experience :D
I have ARB air lockers front and rear in my FJ40. Was out today and loved them as always. I am in the snow/ice often and took out a rear Detroit and installed the ARBs. There is nothing like turning your lockers on and off based on need.
Personally I would put a selectable in the rear if I could only choose one- actually I would ONLY put a selectable in the rear, THEN save for the selectable front- no really! save what you were gonna spend, then save a little more then NEVER look back! You can buy an automatic but you will still lust after a selectable, and need it!
X2
that was THE one improvement on my husband's truck that even I noticed (in the old ages, when we only had his truck for wheeling)
my own truck came with ARBs, and by the time I got it, I would not have taken anything else
if you want to go sequential, the first would be a rear locker
I use the front maybe a forth of the time that I use the rear
I would not put an un-selectable locker in the front
I started with a cheap-lock in the rear, back before the Aussie locker came out. Cost about 2 hundred bucks and went in in an hour. Lasted 4 or 5 years. Went to the Detroit in the rear. Love the Detroit. It ran about 6 bills, but I hear they last forever. I like an auto-locker. But I don't live where ice is a problem. I've heard, more than once, "My air-locker isn't working today!" on the trail.
Auto-locker in the front? I rode with Mr. Manny on the Rubithon, He's got an Aussie in the front of his 40, manual steering, worked great, no problem.
Locker options cheapest to most expensive;
Lincoln rear
Lincoln Rear, Auto locker Front
Auto lockers F&R
Auto Locker Rear, Selectable Front
Selectable F&R
I wheel with a guy that has an auto locker in the rear and ARB in front. This seems to be a good compromise of cost vs performance. In some ways the auto locker in the rear is an advantage. You don't have to think about it, it just works when you need it.
ARB's all around are schweet, I love it.
It is true that air lockers need to be maintained, however if you do regular PM's there is no reason they will be more problematic than any other locker.
I've ridden shotgun with one guy in our club on Rubicon and Fordyce a few times, Lincoln in the rear, Lockrite in the front, 35" MT's, and manual steering. Works great but you better be pointed the right direction when the front engages, you sure as hell aren't going to turn the wheels after it does. :lol:
Aussie in the rear and love it for the money. Little clicking around sharp turns on pavement, but no complaints. Take a few miles to get used to the "twist" feeling when getting on and off the gas in a turn, but no biggie. Worth its weight in Gold offroad!!
Saving my coins for a selectable front.
Snow is not a real issue here for me.
I have Detroit EZ's in the rear, and Zexel Thorson's in the front. I dont have any of the on road locking and clunking that I was warned about, and have been happy with them so far. I had to tow my friend out of the middle of the sand dunes at the last surf and turf. I was pleasantly surprised how the lockers kicked in when I was towing up sand hills, and how the lockers easily pulled me and the rig I was towing up and over hills I thought I would never get over. Best of all, I'll never have any air leaks like my friend does :D.
I have ARB Front and rear. But if i had a advise to give;
- Get the ARB in front, and you mostlikely going to have to get bearing and seal while the front axle is in parts. Get the ARB be done for ever. And you will be soooo happy when you'll want to disengage it to turn. Once engage, you won't turn much, trust me i have PS and fully lock is a pain to steer.
- For the rear, if you do not plan on regearing the axle (changing ring and pinion), go with a aussi locker (if you do not drive the truck on slippery road like snow). The day you will want to change Ring and pinion get the ARB for the rear (but you'll have to put the front appart again....).
So basicly if you are going ARB, think in the long run and you may want to put some new R&P while your at it. Otherwise, ARB front and Aussi in the rear. But i love my ARBs :flipoff2:
