Yaesu 8900 extended transmit mod
Discussion in 'Communication & Navigation' started by Azrocks, Feb 8, 2008.
  1. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    Yaesu 8800/8900 extended transmit mod
    OK, Please don't let this turn into a discussion of whether this is right or wrong. I just want to show what is involved in modding a Yaesu FT8900 for extended transmit. I believe the procedure is the same for the FT8800. I'll check.
    Click HERE for full instructions and pictures on the modification.
  2. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
  3. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
  4. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
  5. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    I found this picture that shows the location on the FT8800 of the diode strip. It looks a little different than the 8900 but bascially the same.
  6. e9999
    e9999 You want to do what...? Moderator
    16,344
    373
    Sep 21, 2003
    PRK
    similar mod to that for the 7800 where you have to remove the "lower" resistor jumper (R1288).
    a bit confusing cuz 2 different documents show 2 different resistors locations but should perhaps be obvious when opened up... looks like there are some differences between the US and euro models too. caution required I think.
  7. alvarorb
    alvarorb Color Geek in Charge SILVER Star
    1,834
    19
    Jun 5, 2003
    Sacramento, California
    Looks like the closest diode to the corner.
    Not too hard.
    Regards
    Alvaro
  8. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    Yup, that's the one.
  9. e9999
    16,344
    373
    Sep 21, 2003
    PRK
    why do you keep on calling these things diodes?
  10. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    Because everything I've read call them diodes. They do look like resistors to me. I'll have to look at the schematics.
  11. _Walker_
    _Walker_
    280
    Apr 6, 2005
    Victorihhhhhaaa
    you guys happy with the 8900? Im thinking of getting into radios etc, and have been looking at this fellow... good buy? It wont do air band or marine band will it?
  12. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    I really like the radio. There's probably a reason to question the practicality of FM 6 and 10 meter though. I got it to expand the usefulness of cross band repeat using 6 meter simplex.
    If you don't need the extra bands, I'd probably look at the 8800. Memory management on the 8800 is a little different than the 8900 as well.
    The dual receive is wonderfull. There is also a home channel scan that is really useful. With it I can monitor two channels on one side of the radio while scanning all frequencies on the other side.
    There is an AM receive mode that I use to scan aircraft frequencies. Along with every open repeater in AZ, I also have police, fire, fbi, fema, dps, some other public service freq, FRS, GMRS, aircraft, and some others. Like all HAM radios, it doesn't scan fast enough to be a super effective scanner. At some point I will get a dedicated scanner.
    Anyway, back to your original question. The 8900 is a great radio. For the price differential I felt it was worth getting the FM 6 and 10m. Go to Eham.net and look at the reviews of anything you might be interested in.
  13. Pskhaat
    Pskhaat
    2,629
    1
    Aug 19, 2003
    Morrison Formation
    Would you be willing to share the list? :)
  14. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    Sure! I can send either the excel spreadsheet or if you are using the same programing software and have the same radio I can send the direct programming file. Let me know.
  15. _Walker_
    _Walker_
    280
    Apr 6, 2005
    Victorihhhhhaaa
    are there any simmilar radios that can both receive AND transmit on FM as well as AM? im looking for a unit I can use when wheeling, but also use for work (Airband)... and id rather not have to dish out for two radios...
  16. psfpilot
    psfpilot
    766
    Jun 8, 2005
    x2...is there a possibility of transmission and/or reception on UHF and VHF aviation bands with this mod?
  17. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    Couldn't tell you. Here's what the mod leaves you with on the FT8900. There may be more but this is what I'm sure of.
    TX: 28-29.7 / 50-54 / 144-148 / 150-170/ 430-470 MHz (USA)
    RX: 28-29.7 / 50-54 / 108-180 / 320-480 / 700-958 MHz (Cellular blocked in the US)
    TX: FM
    RX: AM/FM
  18. mrlocksmith
    mrlocksmith
    422
    Media:
    9
    2
    Sep 9, 2007
    Vegas Baby !
    I may be wrong but dont the AV bands use AM still, This is an FM radio
    Mark
  19. Azrocks
    Azrocks
    532
    2
    Dec 27, 2005
    Tucson / Vail, AZ
    There is an option in programming that allows reception of AM but it is FM transmit only. I can scan aircraft and DPS AM bands.
  20. nakman
    nakman addict. Supporting Vendor
    2,171
    157
    Jul 30, 2003
    Broomfield, Colorado
    This is cool stuff, thanks for posting that. I agree it's a good idea to have this capability some day, kind of like knowing CPR. I hope I never need either. ;)
