Splatter problem
Hey guys,I was wonder if maybe you could answer something for me.I'v been welding same harley exhaust pipes that I make and have been doing it at work on our MIG and have no real problems.But I decided to buy a welder and do it at home.The problem is splatter.I have it big time at home.I use argon as a gas but the weld came with flux core wire.My question is..does it matter if the wire is flux core AND you use a gas.I shut the gas off to no real difference.And I switched the terminal leads in the welder as stated for gas or flux.But I got to thinking that if the manufacturer wants to switch the ground depending on gas or no gas how does flux work into the mix since flux would be one way and gas the other and I'm using BOTH.
Any suggestions would be appreciated.I was going to go buy some other wire but I dont know if its the weld,me or the wire.Oh and the welder is a 220v 110amp chicago electric as seen here http://www.harborfreightusa.com/usa...do?itemid=94164&CategoryName=&SubCategoryName=
Thanks
Posstal AKA Ralph
Thanks
Posstal AKA Ralph
