very simple questions
Discussion in '40- & 55-Series Tech' started by johnny, Apr 8, 2003.
  1. johnny
    johnny
    83
    Mar 12, 2003
    1) do i need a gasket b/w my weber and the mounting plates or just b/w the plates and then intake manifold
    2) what does it mean when i split the exhaust/intake man. gasket? it split b/w exhaust on cyl. 4-5. its 1 year old and the kevlar one?
    3) where's the carb, preheat flapper valve?
    thanks in advance
  2. toddslater
    toddslater SILVER Star
    1,498
    2
    Oct 31, 2002
    Kennett Square
    Well, here goes a stab at it.
    yep
    not sure where your going here ..a little more info would be helpful...are you asking about the gasket that is between the intake and exhaust manifold ?
    the flapper valve is located in the lower section of the exhaust manifold...just above (maybe midway) the flange for the downpipe.
  3. johnny
    johnny
    83
    Mar 12, 2003
    as to #2. i was just wander if there should be any concern. after inspection it looks like its just the gasket was really crappy. after it was heated it became very stiff and cracked and broke very easily.
    tip of the day. don't buy the kevlar manifold gasket, its total crap.
    as to #1...yep to gaskets b/w the carb body and geaskets for all the plates, or yep to just the plates.
  4. toddslater
    1,498
    2
    Oct 31, 2002
    Kennett Square
    To no. 1 gaskets between manifold and plate and gasket between plates and gasket between carb and plate.
    Regarding no 2. if it is the manifold (to head) gasket that is giving you woes...replace with a Felpro and use liberal amounts of permatex copper.
  5. Eternal
    Eternal
    247
    Jan 3, 2003
    on #2 I found also that if the your manifold is warped at all like mine is I used 2 gaskets together and it works perfect.
    Best of luck
    Eternal-still not movin
  6. plan66
    plan66
    31
    Jan 28, 2003
    For Q1, Gaskets everywhere as mentioned. You might want to use a thicker heat insulator type gasket if you find the carb getting too hot. Otherwise can get fuel boiling in the float boal :p.
    Q2: If you don't hear the exhaust leak yet, you might just put off pulling the manifolds for now. Although yours should go no problem if you replaced it a year ago. You did use high heat antiseize on the exhaust studs right ::)?
  7. johnny
    johnny
    83
    Mar 12, 2003
    everything is fine now. i never knew of the flapper cuz i've never had one in my ride. i always had headers, i got my crusher from my brother and i only know how to fix whats on it. so i plead my ignorance in the case of a flapper and ballast resistor that i have never had.
    as for the ex/in. gesket, i already put on my new one and figure i didn't need to use copper. if i am mistaken please someone warn me, i'd rather redo it now before i put the carb on.
    thanks
  8. FJKen
    FJKen
    31
    Jan 12, 2003
    Johnny:  I replaced my exhaust/intake gasket a couple months ago.  Took Todd's advice on the permatex,  :bow:  and I used a double gasket from felpro on Todd's advice also.  It has worked flawlessly, and I think it will hold for a long time.  I guess my .02 is that you don't want to do it again in 6 months..or even a year.  I don't think you screwed up by using only one gasket and no permatex.. now..if you had headers...I'd say take it off and do it again.   Good luck either way!
  9. johnny
    johnny
    83
    Mar 12, 2003
    thanks and thanks. advice taken, double gaskets, much apreciation.
  10. Webster
    Webster
    236
    Feb 20, 2002
    IS the permatex copper you refer to the spray stuff or the copper RTV in the tube. Is the felpro gasker the metal faced style or the composition gasket. I have a leaky manifold with brand new gasket need to try your ideas. &nbsp:Does it help to bold down the manifold to the head before tightening the heat riser bolts?
    Thanks!
  11. toddslater
    1,498
    2
    Oct 31, 2002
    Kennett Square
    webster,
    It's the permatex high temp copper rtv in a tube. The permatex gasket (part number MS 22813) has metal (for the lack of a better word or clear thinking today) embosses around the intake and exhaust ports. My heavily subsidized and highly scientific research into the subject matter...(looked at the gasket provided with my header, looked at car quest brand, and looked at the Felpro) lead me to buying the Felpro. And, I would say yes to bolting up your exhaust manifold with out the heat riser. FWIW, I found it easiest to get good alignment by bolting up the exhaust with the first and last (furtherst forward and furthest rearward) first. Align it and snug it down pretty good then bring on the intake etc...
