I've read that guys have replaced the dirty element with cotton from a cotton ball.
I removed mine from the engine and used the Seafoam spray to try and break down the carbon in it. I sprayed in all the ports, let it sit, applied vacuum, sprayed some more, let it sit overnight, then sprayed it some more. I figured I couldn't screw it up any worse than it already was and I could buy another one if it ruined it.
I cut down a wrench to get to mine, although you can do it with a smaller adjustable. I think it's 27mm
The thing circulates exhaust gases; I doubt the diaphragm is rubber. Soak it in penetrant, too, before you try to remove it. Those fittings are rusted tight! Put it back together with some hitemp anti-seize and you'll never have the problem again.
After a year and a half of fiddling with my emmisions systems (in an attempt to solve my hesitation/stuttering problem at around 1800 RPM) and about a week out from completely desmogging my cruiser, I finally solved this mystery. My stuttering was solve by disconnecting the tachometer. Simple as that. Wow, what a difference!
Here's a new problem: when I disconnected the tach at the coil, my A/C compressor stopped working. If I plug the tack back in, the compressor comes on, but engine stutters again. Anybody have any insight as to why this is? THanks.
Thank you to everyone who takes the time to share their experiece on this site. It's amazing the information and expertise that is available. thanks to all the excellent info available on this site.
I have been working through these possible fixes, and improving my drivability with each step. I checked fuel, vacuum, egr, each made slight improvement, but the FIX, the absolute FIX for my 84 FJ-60 was disconnecting the Tach at the ignition coil. Thanks so much for the tip. I love the tach, so now I have to figure why. I just bought the 84 and putting it on road with parts off my 87. I have the coil and ignitor off the 87 that can swap out, or the tach unit itself. May also find in the wiring, but it is fixed and that is what matters for now. 100% improvement in drivability.
Tom, where do you live ? You able to wrench?
