TCSTARK
Master Debater & Cunning Linguist
I picked up this project in April. I have been busy sorting out all of the parts and determining what direction I will be taking it in. I am using this thread, initially, to document my electrical and engine components so that I can get a quote to put her together.
Here is a list of parts not pictured:
American Autowire Highway 22 harness kit
- ignition switch
- Hazzard
- headlights
- Single and double crimper tools
- American Autowire Copper Ground Kit
- 22 wire bulkhead adaptor
- Ididit 33" Tilt Steering Column
- BTB Products Firewall Adaptor
- Slip Shaft
- DD Ujoint and 3/4 36 spline Ujoint
- Saginaw 4.25 Turn Box
- 2" Drop Pitman Arm & Chevy TRE
- 4x4 Labs Mounting Kit
- Chevy to Toyota Drag Link
Delphi Weatherpack Kit 1505
Digital Dakota Gauge Cluster
- GPS Speedometer
- PSI/Boost
- Diesel Alternator Adaptor
- Electric Fan Controller
- fuel sending unit
- Downey 'Conferr' 22 gallon auxiliary gas tank
- in-tank fuel pump adaptor (if needed)
- Ron Davis Radiator 4 core radiator
- Taurus electrical fan
- 3b Diesel Rebuild Kit
- 13bt turbo
- Racor water separator
- 12v aftermarket high output alternator
- ignition switch
- Hazzard
- headlights
- Slip Shaft
- GPS Speedometer
- PSI/Boost
- fuel sending unit
- 13bt turbo
