sucky turning @ low rpms
Discussion in '40- & 55-Series Tech' started by rusmannx, Jul 21, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    my power steering doesn't seem to give the juice when idleing. i've been reading these techs about increasing pressure and flow.
    is there any downside to this?
    will it still handle on the road at highway speeds?
    i'm only running 33's, but i always find myself reving a little to get the tires to turn with any force.
  2. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    Mine is the same way. I have come to the conclusion that my steering box is not working properly. I am trying one of those conditioning additives to see if it helps. I hope so, I really don't want to replace the box.
  3. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i haven't thought about the box being an issue...
    i don't know how to troubleshoot the situation, i just figured my pump wasn't pumping hard enough or moving enough flow.
  4. roscoFJ73
    roscoFJ73
    13,081
    Media:
    3
    223
    Jul 22, 2003
    Perth Western Australia
    I think the pump can be pressure tested in the car.If the pressure is down it probably needs new vanes. You could probably check the steering box by lifting the front wheels off the ground and getting an asisstant to turn the steering wheel with the engine off and see if it feels too tight. Listen for noise and place your hand on the steering box to feel for any grating
  5. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    What pump are you running?
    What steering box?
  6. sfrolich
    sfrolich
    187
    Jan 23, 2003
    San Jose, CA
    I had the same problem and it turned out to be a bad PS Pump.
