Steering Gear Box Leaking.
Discussion in '80-Series Tech' started by Wrench, Apr 5, 2003.
  1. Wrench
    Wrench One Bashed Up 80
    4,492
    178
    Mar 27, 2003
    My steering gear box is leaking from where the steering wheel shaft goes into the gear box. Just below the u-joint area.What can I do? Is this an easy repair? Anyone familiar with the gear box?
  2. bjowett
    bjowett Supporting Vendor
    3,051
    544
    Oct 28, 2002
    Western Massachusetts
    I've had many of the pre 80 series boxes open for seal replacement... not terribly difficult. It would be best to pull it out of the truck.
    I recently obtained an FZJ box and Toyota has changed the upper bearing/seal area. If the seal is simply worn and bad, it should be an easy R&R. If you have play in the upper shaft, a seal alone may not do it, for long. Not sure how the adjustment for the shaft takes place on the box... maybe shims? The early box has and easy adjustment.... Sorry, it's early, and I'm still sleepy.
  3. Wrench
    4,492
    178
    Mar 27, 2003
    Yeah the shaft has no play so I think it is just the seal. Is that hard to replace? And can I get the seal by it's self? I was told not to mess with the steering box. That it is a pain in the butt to work on.
  4. bjowett
    3,051
    544
    Oct 28, 2002
    Well, just for you, I ran out to the garage and popped (partially) the section off the 80's box that contains the input shaft and seal. Look like you'll have to do a basic break down of the box, R&R most of the guts, then press the input shaft and bearing out of the housing to get to that seal. If anyone knows different, please chime in! The 62 and earlier box is much easier, just spin the large bearing preload cup off the top, R&R the seal, and back on.
    You should be able to get just that seal. If you go for the break down, make sure you keep things extra clean.
  5. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    The seal is not available alone. You must buy a PS gear major gasket kit. It is cheaper than a $2700.00 steering gear, however, so be careful during teardown.........
  6. bjowett
    3,051
    544
    Oct 28, 2002
    Bummer.... you can get it for the older box. My parts guy thought it was a rebuild kit only, but we found it.
  7. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    cdan,
    Did you mean $2700.00 steering box or $270.00 steering gear? :dunno: Is your gear stuck or your 0?
    Bill
  8. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Two thousand seven hundred dollars..(US)...... :eek:
      Nolo poopo....... :tear:
    The spool valve by its self is a bargain at Eight Hundred dollars....(US)
  9. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    I present myself to the group, hat in hand. :bow:
    The steering gear price I pulled from my feble mind was in error as well as the spool valve price .
    I herewith present corrected numbers:
    Steering gear, complete: 44110-60211 $2,314.29
    Spool valve only: 44120-60180 $1,021.09
    gasket set w/top seal: 04445-60050 $119.71
    I was close though :eek:
