I have been looking for one of these for a while and finally one showed up on Craigs List that looked great and was only a few miles away.
I need to get this thing ready to travel in short amount of time as we will be heading to Canyonlands in a few weeks so for now I am just focusing on getting a few things in place.
Eventually I want to put a nice lid on this but for now I have put together a removable frame to hold our roof top tent.
The frame is 1" sq 11ga tubing and the receivers it fits into are 1.25" 11ga square tubing.
I got the pins through McMaster Carr
McMaster-Carr
I figure with this set up I can take the frame off and use the trailer for all the landscaping and general junk I need to tow around this summer until I make it a dedicated camping trailer.
Next step was to cut a tail gate, this was about like cutting the hole for the snorkel on my 80 series, you know if you make a mistake you are living with it from that point on.
I used the ideas from others on the forum on how to weld up the tail gate.
I wanted a smooth transition out of the bed of the trailer so I welded the bed to rear frame and then weld filled it in to make it flat.
I found some heavy duty grease-able hinges from Northern Tool
Buyers Steel Hinge with Grease Fitting — 6 in. | Hinges + Fasteners | Northern Tool + Equipment
I also got my latches from Northern Tool
Buyers 1/2in. Spring Latch Assembly | Hinges + Fasteners | Northern Tool + Equipment
So I think I have most of the welding done now, now I have gobs of grinding to clean up all my crumby welds.
The tires on this trailer where original and look like new they even still have the rubber whiskers from the mold but unfortunately they are dry and cracking in the side walls and I can't find a a spare the same size so I decided it best to replace them.
I am going with Cooper Courser Traction LTs, they are 7.5 x16 so they are about 2" taller and a little wider than the stock tires but it will keep that same look.
Next step, grind , grind , grind, then get the tires mounted and then pack the bearings and I should be ready for its first trip out!
McMaster-Carr
