Replacement Plugs for FZJ
Discussion in '80-Series Tech' started by tenncrusher, Apr 21, 2003.
  1. tenncrusher
    tenncrusher
    168
    Mar 28, 2003
    Nashville, Tennessee
    What replacement plugs do you recommend on a 1996 Cruiser?
    Better luck with any particular kind?
    Thanks in advance.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Nippondenso K16R-U
    Toyota part number 90919-01176
    You can't go wrong there. Suggested list price $1.97 each.
    Regards, Dan :beer:
  3. moralien
    moralien
    381
    Apr 17, 2003
    On the catwalk.
    Cruiserdan is spot on...Only put back OEM
    ND K16R-U
    NGK BKR5EYA
    Either will work. Get anything else and you will be sorry.
    Make sure the gap it set at 0.8mm or 0.031in...
  4. Jacknasty
    Jacknasty
    45
    Apr 15, 2003
    I just put the Bosch Platinum plugs in my 96 Cruiser
    Made sure they were gapped properly and they have been fine. $1.99 each
  5. landtoy80
    landtoy80
    5,668
    240
    Mar 13, 2003
    North Front Range, CO
    I went with NGK Iridium Spark Plugs. Very$$ I have no complaint with them of any NGK plug, Execpt for use in my 5hp Mercury outboard. The only plug that could get it to run smooth was the Split Fire. They don't do anything in my Toyota's but they do some thing to small engines that the others can't. I have tried dumping all kinds of oil gas and oil mixes into the 4cycle BS lawn engine and it doesn't foul out.
    kurt
  6. Wrench
    Wrench One Bashed Up 80
    4,490
    176
    Mar 27, 2003
    NGK Iridium Spark Plugs are excellent plugs! They are made from a very hard metal. And wiill last longer than Platnuims.They are rated to last to 90K. Give better throttle response and resist fouling. Require less voltage to spark and deliver increased burn efficiency, spark at leaner air/fuel mixture, produce better gas mileage and higher horsepower. Awesome plug!!
