Replacement gas tank
Discussion in '40- & 55-Series Tech' started by firedawg24, Mar 29, 2003.
  1. firedawg24
    firedawg24
    6
    Mar 29, 2003
    I was wondering if anyone had any experience with the MAF long range replacement tank that fits under both the passenger and driver seats. Or if anyone knows another MFG that sells them.
  2. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    I built my own for under the rear of the truck between the frame rails of my '71 fj40. FYI I used a tank sealer from http://www.eastwoodco.com/ (then just search for tank sealer) I really like it out of the passenger compartment.
  3. firedawg24
    firedawg24
    6
    Mar 29, 2003
    What material did you build it with? How much welding prowess must one have in order to do this?
  4. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    I used 11 gauge mild steel and a wire feed welder added some baffles inside to prevent sloshing. as far as welding goes make several passes to make sure you get all the large holes filled, and then the sealer will do the rest.
  5. Pete_S
    Pete_S
    74
    Feb 3, 2003
    Did you create a steel box with a filler neck? Do you have this on your "purple rig" now? How long have you had it? What did you use to cut the pieces? Was this someone elses design? Blah, Blah, Blah.........
    I am VERY interested in getting rid of the underseat tank in mine. Any information is greatly appreciated!
