I just bought a 94 LC and the rear wiper isn't working. When I turn it on I can hear a slight humming noise but it's not moving.
Any help would be appreciated.
If you hear the motor humming, it might just be the linkage between the motor and the wiper.
Disassemble the trim that hides the motor and linkage on the hatch, turn on the motor and see if it's moving part of the linkage. On mine, one of the "joints" was stripped so the motor would move, but he linkage just "spun".
Unfortunately, if that's the case, you still might have to buy the whole assembly as I don't think you can just buy the linkage. At least, that's what I had to do, but I just popped the linkage off the new assembly and stuck it on the old motor.
If that's not your case and you need a motor, but your linkage is good, then PM me... I've got a brand new motor waiting for you...
x2, friend did the same and it fixed his.... I still need to fix mineI had the same exact issue as you describe, I couldn't figure out the problem so I took it to the local Lexus dealership...
Turns out it just needed to be re-grounded, as the old grounding point had failed.
Simple fix and a minor charge, after that all issues with the rear wiper were gone
Check on your grounds before looking at sinking money into a new motor assembly
