pulling the diffs...
Discussion in '40- & 55-Series Tech' started by 72tlcnelson, Sep 17, 2003.
  1. 72tlcnelson
    72tlcnelson
    119
    4
    Jan 15, 2003
    What's the scoop on pulling the 3rd member or I guess the pumpkin out of an FJ40 axle? I've got front and rear ARBs and the local 4x4 shop said if I can pull just the differential it would save me $ on the install of the ARBs. I've been looking for write ups on it but to no avail...Advice...is it too technical? Never tried it before... ???
  2. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Rear is a breeze. Drain. Remove cover. Remove crosspin bolt, crosspin, block, and c-clips. Pull axles outward to clear third member. Remove third member.
    Front a bit more involved. Drain. Remove hub lock, hub, and spindle. Pull axle outward. Remove third member.
  3. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,099
    Jan 15, 2002
    Toquerville UT
    Check the instructions for EZ-Lock installs in rear axles and for knuckle rebuilds on the fronts. Pretty much sums up the process.
    Saves you a pile of $$$ since the chunks are removable and the shop doesn't need to do all the "piddly" work dropping everything out.
    You'll need 4 jackstands to hold up yer rig...good ones too, not those useless 1-ton POS thingies (I have 4, they are useless)
  4. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    Sometimes you will need to provide a good amount of persuasion. There are several ways to do this.
    Use a jack and lift the pinion slightly. Be careful not to put too much pressure thoug.
    I use the screw driver/chistle to try to pry them apart.
    One thing to keep in mind. They are very heavy if you are laying under them. ;) IIRC about 75 lbs.
  5. nuclearlemon
    nuclearlemon not an addict Moderator
    15,587
    Media:
    87
    405
    Jan 30, 2003
    meh-ico, colorado
    [quote author=woody link=board=1;threadid=5346;start=msg42042#msg42042 date=1063799489]
    [/quote]
    no they're not...they're great for holding up empty axle housings.
  6. Gundy
    Gundy
    3,182
    2
    Jan 2, 2003
    Dweller on the Threshold
    tool tips re diff pull
    A hub socket is a good thing
    Replacing axle seals not a bad idea
    Pliers to get that darn ring clip out ( I had to grind some to get the points
    small enough)
    Diff gaskets are nice, but black rtv will work.
    Those pumpkins are VERY heavy and often seem welded to the axle.
    I used a slight lift from wood block placed on a floor jack. Be very
    careful.
    Be careful on the re-install. The ARB can get cracked while you
    struggle with a HEAVY pumpkin you are trying to re-install in close spaces.
    Pack the birfields while out of the axle.
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    If you use a tranny jack it's a piece of cake.
