psi, amps, ohms and such
Discussion in '40- & 55-Series Tech' started by ScarboDP, Jan 8, 2003.
  1. ScarboDP
    ScarboDP
    51
    May 30, 2002
    I am in the process of making a custom instrument cluster using autometer gauges. I was wondering what specific psi to get for oil pressure, the temps to get for water temp and the amps to get for the ammeter. Ive searched the haynes manueal and the chassis and body manual and can't seem to find any numbers i can use as a refrence. Thanks for any help
  2. Erics75
    Erics75
    81
    Jun 14, 2002
    Just looking in a summit catalog I would say 100 psi on oil, 280 degrees on water and amps should be about 60. I think These are pretty much standard and should cover more than enough for stock or mildy modified.
    Eric
  3. woody
    woody Internet Fireman Staff Member
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
  4. ScarboDP
    ScarboDP
    51
    May 30, 2002
    thanks just what i was looking for
  5. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    307
    Dec 13, 2002
    Knee deep in hookers and gin
    I found many aftermarket water temp guages to not go high enough. Many topped out at 220. GM fan switches don't turn on until then.
    Also, I sure wouldn't put an amp guage in. Especially if you are upgrading to a high amp alternator. A volt guage can tell you much of the same info without running all of the alternator output through your dash panel. Most amp guages are an electrical problem waiting to happen.
    JMHO
  6. woody
    10,332
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    I'll second the amp gauge comment...switch to a volt and it tells ya jsut as much!
  7. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    My amp gauge caused me the pain of taking in my Alternator thinking it wasn't charging. The gauge went bad and an amp gauge must be connected in series, So I didn't have a complete circuit anymore
  8. ScarboDP
    ScarboDP
    51
    May 30, 2002
    Thanks ill switch over to voltmeter then. Also, I'm putting a fuel gauge in the aux. tank and was wondering what ohms to use. Does it matter?
  9. Erics75
    Erics75
    81
    Jun 14, 2002
    I think what you will have to do is use an ohm meter and check your senders resistance with the float in empty and full position, or measure the resistance of the sender if its in the tank already, when the tank is empty and full.
