do you have to get your vehicle emissions tested?
OK, got you. just checked this. 2019 - 1997 is 22 years. so yeah they want it.
no. they're previously posted pics. just doing a sort of illustrated and labeled cheat sheet for myself as i get a parts order together. figured to label everything so it is a paint by numbers effort and to post them up when i am done in case they can help others...have you pulled the upper plenum off and pulled the injectors out?those pics are they your vehicle?
Next you have some cleaning to do. I used Carb cleaner (same thing as throttle body cleaner) from the local autozone. I tried to get as much of the oil and carbon deposits out as I could, especially in the smaller ports of the manifold chamber.
The first 2 pictures show the usual areas of carbon blockage as they are the passages with the least space. The dashed line is a straight passage connecting a vaccuum hose from the top of the manifold to the bottom. It is circled in the second picure.
The last picture shows some of the EGR and EVAP components.
1. VSV for EGR (I replaced mine in this project)
2. VCV for EVAP
3. Check valve for EVAP (make sure it is facing as shown in the picture when you put things back together. It is a one way valve and you can test its function by blowing on either end.
View attachment 601160View attachment 601161View attachment 601162
Is this the part number for #3?
44730-28010
25620-66011 | EGR valve assembly | egr/vacuum |
90910-12079 | Vacuum switch valve | egr/vacuum |
25870-66011 | EGR vacuum modulator | egr/vacuum |
16261-66040 | Water bypass hose | egr/vacuum |
16264-66021 | Water bypass hose | egr/vacuum |
16267-66020 | Water bypass hose | egr/vacuum |
25695-66010 | EGR vacuum hose | egr/vacuum |
90917-10049 | Check valve | egr/vacuum |
90980-11153 | Connector housing | egr/vacuum |
90413-04019 | Three way | egr/vacuum |
90910-12043 | Vacuum switch valve | egr/vacuum |
90999-92006 | Vacuum hose | egr/vacuum |
90999-92007 | Vacuum hose | egr/vacuum |
90925-03192 | Vacuum control valve | egr/vacuum |
22271-66010 | Throttle body gasket | egr/vacuum |
17179-66010 | Intake manifold gasket | egr/vacuum |
17171-66010 | Intake manifold gasket | egr/vacuum |
25627-66010 | EGR valve gasket | egr/vacuum |
44773-60150 | Brake booster vacuum hose | egr/vacuum |
90480-24015 | Check valve grommet (brakes | egr/vacuum |
44730-28010 | Brake booster check valve | egr/vacuum |
90999-92003 | Hose vacuum | egr/vacuum |
90999-92004 | Hose vacuum | egr/vacuum |
90999-92008 | Hose vacuum | egr/vacuum |
95337-06020 | Hose fuel | egr/vacuum |
95333-06010 | Hose fuel (100cm) | egr/vacuum |
25701-66011 | Vacuum control valve | egr/vacuum |
I like your style, do it once do it rightHere's a list of parts I ordered (all still avail from T):
25620-66011 EGR valve assembly egr/vacuum 90910-12079 Vacuum switch valve egr/vacuum 25870-66011 EGR vacuum modulator egr/vacuum 16261-66040 Water bypass hose egr/vacuum 16264-66021 Water bypass hose egr/vacuum 16267-66020 Water bypass hose egr/vacuum 25695-66010 EGR vacuum hose egr/vacuum 90917-10049 Check valve egr/vacuum 90980-11153 Connector housing egr/vacuum 90413-04019 Three way egr/vacuum 90910-12043 Vacuum switch valve egr/vacuum 90999-92006 Vacuum hose egr/vacuum 90999-92007 Vacuum hose egr/vacuum 90925-03192 Vacuum control valve egr/vacuum 22271-66010 Throttle body gasket egr/vacuum 17179-66010 Intake manifold gasket egr/vacuum 17171-66010 Intake manifold gasket egr/vacuum 25627-66010 EGR valve gasket egr/vacuum 44773-60150 Brake booster vacuum hose egr/vacuum 90480-24015 Check valve grommet (brakes egr/vacuum 44730-28010 Brake booster check valve egr/vacuum 90999-92003 Hose vacuum egr/vacuum 90999-92004 Hose vacuum egr/vacuum 90999-92008 Hose vacuum egr/vacuum 95337-06020 Hose fuel egr/vacuum 95333-06010 Hose fuel (100cm) egr/vacuum 25701-66011 Vacuum control valve egr/vacuum
Looks familiar. I just I'd all of this last year. Here's to hoping I don't have to touch it for a while.I like your style, do it once do it right
Cleared my P0401 code with help from this thread. Have a ‘97 LC and there was cracked tubing at the nipples that run through the intake plenum. Both nipples on either end were corroded but I was able to use a pick to gently clear the hole and push it open. Replaced modulator and vsv, replaced all 3.5mm tubing plus more and cleaned intake to egr port.
It was more challenging to put everything back together than expected. One of the intake plenum nuts gave me fits to get back o
Good stuff about a year ago I did the same thing replaced all my spark plug seals check the valves had my whole intake cleaned checked or replaced bench tested all the components and replaced all the tubing.Cleared my P0401 code with help from this thread. Have a ‘97 LC and there was cracked tubing at the nipples that run through the intake plenum. Both nipples on either end were corroded but I was able to use a pick to gently clear the hole and push it open. Replaced modulator and vsv, replaced all 3.5mm tubing plus more and cleaned intake to egr port.
It was more challenging to put everything back together than expected. One of the intake plenum nuts gave me fits to get back on.
Partsouq and Toyota parts deal have detailed parts diagrams.Does anyone have a part number for the two washers/gaskets for the fuel line banjo bolt?
You talking about the electrical connector harness that goes to the vac switches and injectors and all that?Is there a part number for the VSV harness that runs under the upper intake manifold?
