Oil pressure
Discussion in '40- & 55-Series Tech' started by fj40crusher, Jun 18, 2003.
  1. fj40crusher
    fj40crusher
    463
    4
    Nov 7, 2002
    Pacific NorthWest
    I have a ford v8 302 in my 74 (PO did this, not me). Anyway, when I start it up my oil pressure (after market guages, yes they are working properly) is at about 35-40. When it's warmed up and driving it's usually right around 20-25. When I come to a stop it drops to 0 and doesn't rise again until I get into 2nd gear. This obviously has me highly concerned. The oil is fresh, it's 100% synthetic ( I think it's 10w30 but I would have to check when I get home) and I know it's full.
    Cause? Cure?
    Thanks for the help
  2. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    my beretta does the same thing.......i've been told i have too much clearance between the main bearings. time for a 3.1 stroker kit! :G
  3. sfrolich
    sfrolich
    187
    Jan 23, 2003
    San Jose, CA
    Three things you can try:
    1) Try 60W oil (20-50W if in cold climate)
    2) Get I high-volume (not high-pressure) oil pump
    3) Rebuild bottom end of the engine
    It is more than likely main bearing clearance.
    Scott
  4. proffittscruisers
    proffittscruisers Supporting Vendor
    95
    Feb 5, 2003
    It's ok to have 10 lbs per 1000 rpm, but not 0. Drop the pan, get some plastiguage, and check the bearing tolerances
