Hi everyone, I picked up this LTT-FE last year as a project trailer for an ice house but have just been to busy to get to it so I thought I would put it up for sale...$2500.00. This is a tough aluminum trailer made by Schutt Ind in Wisconsin, a great project trailer. Below are the specs on this one. I'll get some better pics uploaded this week, these were just a couple I took when I picked it up. I do have a wiring harness converter and a new pintle hitch that will go along with the sale.
- OVERALL LENGTH: 167.5 inches (425 cm)
- DECK LENGTH: 120 inches (305cm)
- DECK HEIGHT: 34.5 inches (88 cm)
- OVERALL WIDTH: 86 inches (217 cm)
- OVERALL HEIGHT: 45.5 inches (116 cm)
- TRACK WIDTH: 72.5 inches (184 cm)
- GROUND CLEARANCE: 16 inches (41 cm)
- TIRE SIZE: 37 X 12.50R 16.5LT
- RIM SIZE: 16.5 X 8.25 HMMWV standard 2-piece steel wheel
- MAXIMUM VEHICLE WEIGHT: 4200 lb (1905 kg)
- CURB WEIGHT: 1350 lb (612 kg)
- MAX PAYLOAD CAPACITY: 2850 lb (1293 kg)
- DESIGN: Frame and body are composed of aircraft aluminum alloy with reinforced high strength steel drawbar and sling/tie-down points.
- SUSPENSION: Independent Rubber Torsion Axle
- SHOCK ABSORBERS: Hydraulic, double-acting
- ELECTRICAL SYSTEM: 24 Volt system
- BRAKES: 12 x 2 inch inertia-actuated hydraulic surge brake system. Independent hand-brake levers for left and right side parking brakes.
- DEPARTURE ANGLE: 27 degrees
- TURNING RADIUS: 80 degrees
- FORDING: 60 inches (152 cm)
