Low Coolant Alarm Light
Discussion in '80-Series Tech' started by landtoy80, Mar 27, 2003.
  1. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Is there a way to make the overflow coolant tank have a low level warning alarm/light?
    kurt
  2. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    It may be worth a trip to the junkyard....when pulling an intake off a beretta for my car, i noticed that, like mine, it had a low coolant sensor in the radiatior. it looks like it could be removed easily, and im sure you could hook up a light to it....
    -Max
  3. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    That would help save the motor, if you get a leak, you get a warning before it gets to hot.
    kurt
  4. bkgiii
    bkgiii SILVER Star
    479
    Mar 28, 2003
    Gulf Coast
    Hmmm.......I like the idea of this mod.... :)
  5. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    I dug this old post up and still like the idea.
    Any one done this mod yet?
  6. alia176
    alia176
    9,639
    436
    Aug 21, 2003
    Tijeras, NM
    You can wire up the motor circuit such that the wiper won't wipe if the washer is at low level. Basically you need a normally closed contact through the "low level" float thing. No need for extra lights and other doodads.
    Ali
  7. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    Ali...I think the thread is about radiator overflow level, not wiper fluid.
    I remember seeing this thread a long time ago and thought it was a good idea. Problem is there are so many good ideas and not enough time to do anything with them... :rolleyes:
    With the holidays, maybe I'll take a run down to the radio-rat and see what I can dig up. Shouldn't really require any special sensor--it's just detecting fluid level (much like those you see advertised for your leaking hot water tank at home). But where to hook up the indicator light now... ::)
    Tom
  8. landtank
    landtank SILVER Star
    18,423
    601
    Mar 27, 2003
    Groveland MA
    I remember on one of Christo's write ups that he used a socket in the dash for a warning light. It was a "clogged filter" light for the diesel application. It was in his remote winch control. Anyway, it was 2 rows of dots with an arrow pointing down I think. It'd look pretty good.
  9. turbocruiser
    turbocruiser SILVER Star
    3,563
    21
    Dec 24, 2003
    If you go to european car parts yards and look, many of the mercedes models (especially old 's' classes like the 560SEL) have a super slick low coolant level mechanism that could EASILY be adapted into any landcruiser. It is a sort of float that when level indicates a properly filled system and when less than level indicates a system that is thirsty for some reason. The float is already engineered to stand up to coolant and heat so you cannot go wrong. In fact, you might find that with some extra tubing, you could even place the entire overfill tank with existing coolant level mechanism into the landcruiser's engine bay. A simple on/off light in or on the dash would be as easy as it gets in terms of an indicator light. HTH Someone. :beer: For All!
