Latest call to my dealer -- valve clear/rear bearings
Discussion in '80-Series Tech' started by erics_bruisers, Jul 15, 2003.
  1. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    So, per C-Dan's post, I called my dealer to see how much they'll charge for a routine valve-clearance adjust and a rear bearing replace-repack --
    They said they don't do valve-clearance adjusts unless there's a problem (he even said, "If it ain't broke...")
    and for the rear bearings, he said it's a sealed unit --
    -- now, even I know his last statement was false --
    -- any ideas on prices before I look at doing this myself??
    eric
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Eric,
    Our service department gets 4.0 hours on the valve adjust and 2.5 hours on REAR wheel bearings and 8.0 hours for the front axle knuckle job. Our labor rate is currently $78.00 per hour. Required parts are, of course, additional.
    Dan.
  3. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    Thanks for this, C-Dan --
    -- does ANYONE get their valves adjusted at $340 labor, or do they do it themselves??
    In Stamford (where I am), the Toy. dealer acts like they don't even know how to do them --
    -- eric
  4. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Whoa! $340 bones! I don't know about the 1FZE, but my local dealer will adjust the valves on my 3FE for $118 out the door... and that's without being a CDan "Smart Shopper."
    -H-
  5. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    -H-
    I read the FSM for the valve adjustment ..... :eek:
    when got to the part about the shims.. ???
    maybe it just sounds more complicated than it really is, but if done incorrectly, I'm sure it would be a lot more than $340 !!
  6. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    It's not too bad 'til you get to the part where you have to remove the camshafts to change the two rearmost shims on #6 cylinder ::) I "ran the rack" in mine at 90some K miles. They were all within spec, didn't touch a shim.
  7. cary
    cary
    3,109
    21
    May 7, 2003
    Does anyone know how much the valve adjusting tool is through toyota? Is there an aftermarket source?
    Thanks
    Cary
  8. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    The lifter press would run about $110.00 and the lifter stopper is about $20.00.
    The tool price list I have is a bit old so these are "best guesses" but probably pretty close.
    OTC may offer a generic version, or perhaps Snap-on.
  9. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    So Dan, I'm sure you don't agree with my service "advisor"'s suggestion of, "If you're not aware of a problem, don't check the clearance", right??
    eric
  10. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    The $340 is starting to sound pretty good !!
  11. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    Unless you watch them (which they won't allow), how are you sure they'll even do it??
    :mad: :mad: :mad:
  12. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Eric,
    The book calls out valve clearance inspections at 60,000 mile intervals. I put mine off til 90k+. I guess you could think of it this way: A tight valve or two ignored could burn, meaning removal of the head for a valve job. I gotta think that would be a touch more than 300 bucks. It may be that they just don't like the looks they get when they hit a guy with a number like that for a "maintainence" item.
    For what it's worth, the job takes a lot of time. I spent most of a day on mine. 4 hours is pretty close for shop time.
  13. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    The 3FE must be a hell of a lot easier. Dealerships in Phoenix are quoting $95 for a valve adjust. Not as many valves or cams I suppose.
    -H-
  14. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    We include all the readings on the invoice for records. Sometimes you just have to trust people. If you have the dealer do it, ask for a copy of the actuall clearance values.
  15. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Christo,
    How many hours do you quote for the valve adjust?
    I know Robbie's hairs are Exactly the right diameter for perfect clearance :D , so deduct for that advantage. ::)
    Dan.
  16. 96Cruiser
    96Cruiser
    543
    Media:
    2
    54
    Jul 14, 2003
    CHARLESTON WV
    yep.the old "you dont have to have that done " quote
    my dealer parts guy called the shop while i was buying some tune up parts and was told at first "those dont need adjusted" but after i "insisted" that there was a 60000 mile frequency, they said "we will check while you wait" and the answer came back "around 500.00"
    i also agree(Eric),its hard to trust people that dont know(that should be doing it regularly)
    makes me want to vacation in Golden Co. and have Christo and co. do it(i know they are straight up!!!)
    doug
  17. sleeoffroad
    6,056
    531
    Mar 27, 2003
    If done during a tune-up, we get 2 hrs plus parts. Valve cover gasket & spark plug seals. That is for a check, not adjusting. That is quoted on a per job basis depending on how many needs adjusting.
    Also, they can not do it while you wait, since the engine has to be cold when you do it.
  18. sleeoffroad
    6,056
    531
    Mar 27, 2003
    That said, we do get more hours on a front axle service than C-Dan. Not sure if theirs include removing a the complete knuckle and replacing the knuckle bearings.
  19. cruiserdan
    20,603
    2,981
    Mar 27, 2003
    Christo,
    Our time does not include replacing trunion bearings but does include packing them and they do pull the knuckles off. Also it does not include birf swapping which, IIRC, you normally do.
    I gotta think that for a guy's Cruiser to be granted an "audience" with Robbie is worth AT LEAST a couple extra hours. :D
  20. erics_bruisers
    erics_bruisers
    2,032
    2
    Mar 28, 2003
    Just talked to my dealer, and they said it's 6 hours labor on the valve adjust and 4 hours on the rear bearings -- almost double the labor times you mentioned above --
    -- C-Dan, isn't there standard times used by dealerships??
    WTF!
    :mad:
    eric
    PS - I loved it when the phone-answering-guy said the valve adjust is "a lot of labor -- we've got to do both cylinder banks" -- now THAT makes me feel comfortable... :p
