greynolds
Slee where did you get that??????
Photoshop?
Not an option on my LX though - that cubby is used for the AHC controls.
After using it for a few days, my results in using the DICE unit have been kind of a mixed bag so far. Sound always comes through and sounds great - definitely an improvement over using the tape adapter. However, the "steering wheel" controls and text display haven't been working very well. The controls and text display worked ok initially, but I've completely lost them for the last couple of days. The text display currently just displays the name of the last track that it had gotten and the controls are non functional - I can still use the iPod to do whatever I want though. I've reset the iPod several times with no change.
A few things I wish that it would do:
1) When in PLAYLIST mode (Disc2), display the name of the current playlist: PLAYLIST * playlistname.
2) When in ALBUM mode (Disc3), display the name of the current album: ALBUM * albumname.
Overall though (when it's working) it's a pretty workable user interface given that the Nav/Radio system wasn't really designed with iPod control in mind.
My LX was dropped off at the dealer on the way home from work for the 15k service (it just rolled to 15k on the nose as I drove into the dealer), but my next step is to disconnect the battery and hope it brings the controls and text display back to life (perhaps the battery will get disconnected as part of the 15k service). If not, I'll have to give DICE a call. I'm definitely concerned that if it's locked up after very little use in the first few days that I'm going to have to disconnect my battery every few days if I want to keep using the controls and text display - definitely not a user friendly experience if that happens.
jditom - do you pretty much stick to keeping it in the Disc1 mode or do you change around a lot? I'm wondering if experimenting with the different modes leads to it getting confused and locking up.
You are not done yet. Now convert the cubby to have a Ipod connector on the bottom, so you just drop it in there and it will connect.
fender, that sounds like an awesome idea. Police departments use the spot for rear air control on the previous generation tahoe (it is up there above the mirror) to put switch controls. Ive seen things from traffic directors to siren controls to even a radio mounted up there. Its in a decent location and should be fairly easy to reach.
If you can do it, go for it...running the wire(s) down to the dash is as simple as taking off the grab handle that is held on by two screws and pulling the A-Pillar trim off. Then you just tuck it up behind the headliner. I had run a pair of wires up to above the rear mirror myself when i had an emergency light mounted just below my mirror.
I'm going for it as soon as all my stuff comes in...I'm also going to hardwire my Val -one radar dector above the rearview as long as I'm doing the wiring and have the a-pillar off...Now I just need to fab up a face plate to hold the sirus in place...a dremel and a couple of tries is all it should take
It seemed like early on after my install it would freeze on the display and steering wheel controls. But if you reboot your iPod it would work. Happened a few times the first week when going from DVD to CD etc. But now a month later and everything is working great. I mostly just change playlists (disc 2) then once I pick a new playlist I go back to (disc 1) so I can change songs from the steering wheel. If all else fails you can disconnect the car battery and that will be like starting over.
anybody explored the video option to play on the screen? I've got an 80g ipod, how cool would that be to be able show the video portion. Would essentially require a connection similar to that used when hooking the ipod to your television. does this company support that?
Greynolds,
How are you planning to run the cable from the Dice unit through the glove compartment to the Pro-Fit mount? Will you still be able to close the glove compartment or will it require drilling?
