in dash stereo
Discussion in '40- & 55-Series Tech' started by Peggsy, Aug 5, 2003.
  1. Peggsy
    Peggsy
    13
    Jun 7, 2003
    just need to know if a standard size head unit will fit in the hole in my dash without having to cut it. There's nothing in there now but the plastic insert that came from the factory. Also, what does it attach to behind the dash, do I need to make a bracket off the top of the heater unit?
  2. JohnL
    JohnL
    358
    1
    Jul 2, 2003
    Peggsy,
    Sorry, what is the model/year?
  3. Peggsy
    Peggsy
    13
    Jun 7, 2003
    oh yeah... 78 fj40.
  4. JohnL
    JohnL
    358
    1
    Jul 2, 2003
    HMMM, not positive, but I believe it is not a standard DIN. You should check Crutchfield.com I've had decent experience with them and they generally send you everything you need, including the harness and bracket.
    I haven't seen someone get one really secure in there (again, not sure about the 78 dash). I have been very happy with the weathertightness, security and look of my Tuffy console between the front seats. Fit a CD head unit in there with an amp hidden in another locker under the rear bench.
  5. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    if its the same as the 79, the hole is the right height, but is too narrow by a couple of centimetres. It should have 2 partial brackets bent out of the dash 1/4 way down the sides of the holes and another one at the bottom of the hole, as well as a nut welded to the firewall as a securer for the radio. I found all the brackets to be next to useless, but by bending one side of the hole a bit larger, the radio fit very snugly, and does not move around at all, even without any mounting screws. normal size radios also just clear the firewall and happily sit on the heater assembly, so there is nothing to it if you can get it in the hole. by the look of things NA yotas got plastic s*** all over the dash which we didn't get till '80+, which may be getting in your way too?
    sam
  6. Peggsy
    Peggsy
    13
    Jun 7, 2003
    It's an aussie one, so no plastic. The bench seat rules out a centre console, but it looks like an overhead console would probably be an easy way to mount it without damaging the dash. It would also give me somewhere to mount the UHF too. Don't s'pose anyone has any good ideas/pics for a cheap home made console to suit a hardtop? I guess I could probably knock one up out of a bit of ply and some carpet?
  7. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    i thought i had a picture of mine around somewhere, but i cant find it. It just a ply plank running across the top with a strip of pine along the face for support. It worked fine and looked ok untill i started putting weight up there - 27meg and sawtron kg107, then it started bouncing round a bit, so i put a strip of aluminium angle the length and drilled the roof to fit support bolts. It works really well now, and supports the weight of the radios and the speakers without moving. As long as the plank stretches the width of the roof, the only mount points you will need are 2 small bits of angle aluminium bent accordingly and bolted to the sunvisor screw holes.
    the entire back section of the ceiling of my car has been done with ply planks. They really provide a handy storage solution. I dont know what i would have done without them over the past 4 years.
    Sam
  8. roscoFJ73
    roscoFJ73
    13,079
    Media:
    3
    223
    Jul 22, 2003
    Perth Western Australia
    Peggsy if your in oz try one of the big car stereo outfits like gardiner electronics or strathfield car sterio .They sell all that sort of stuff for DIY.To support your stereo you can use adjustable hangers. I had a similar problem in a car once
  9. FJ60
    FJ60
    270
    Jun 27, 2002
    my 78 dash had already been beat on (literally) and was still to small for a standard CD player so I enlarged it slightly to the passenger side and pressed on. I like finally having tunes in my FJ40 but it would be more comfortable to control in a center tuff console.
