serenity
Moderator
- Thread starter
- #21
Hmm, I've had a bit of a look on google. It's a bit inconclusive, I saw one setup that used a banjo on the drain plug as the oil return. Most of the guys that had issues with oil returns had the turbo mounted low with a very shallow angle on the return line whereas the return from my turbo is quite steep. Either way I'll run it and see how it goes, if I get oil backing up and excessive consumption I will look into moving the oil return. When I rebuild the motor I will be drilling and tapping the block to run the stock oil feed and return lines anyway.
