how hi is too hi (oil pressure)
Discussion in '80-Series Tech' started by BMT, Aug 4, 2003.
  1. BMT
    BMT
    325
    Apr 1, 2003
    In the last two oil changes I have switched to Valvoline Maxlife 10W-30. I do not know if it is a coincidence or not but my oil pressure will peg at hi cruising along at over 2000 RPM. At idle it's a little less than half. Anyone else have hi oil pressure? ???
  2. Big_Moose
    Big_Moose
    426
    Aug 26, 2002
    BMT
    Mine runs at the 2/3's mark constantly. Did an oil change to 15w50 M1 about 500 miles ago - no change in gauge position.
    My 96 has 80,050 miles.
    (hopefully the picture posts)
    Joe
  3. scottm
    scottm
    3,140
    Media:
    8
    849
    Mar 27, 2003
    Third Coast, USA
    That's wierd. I had a sending unit failure that acted like that in my Audi.
  4. Jonathan_Ferguson
    Jonathan_Ferguson ★ is in the wrong locale SILVER Star
    1,002
    60
    Jul 2, 2003
    Glen Waverley, Victoria, Australia
    1FZ-FE with Castrol GTX 2 20W/50 is about Needle thickness under 2/3 to Needle thickness over 2/3 under normal operating conditions :) in Winter :'(.
  5. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Since I first switched to the smaller filter, my oil pressure went up. It's never pegged, but it was very close to the top. I've gone back and forth between filters, and it stays high.
  6. acf
    acf
    114
    Jun 18, 2004
    Cornelius, NC
    I just switched to that same oil today so I'll report back if I experience anything like that.
  7. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    i'm running M1 15w40. at highway hi revs I'm right at the top mark, not the upper range mark but the one at 2:00 o'clock.
  8. e9999
    e9999 You want to do what...? Moderator
    16,373
    388
    Sep 21, 2003
    PRK
    as far as I can tell, my pressure gauge never goes to more than 1 needle width above the 2/3 mark. Relief valve opening, I imagine.
  9. ultimauk
    ultimauk
    141
    Feb 7, 2005
    FWIW, my 93 270k runs the 2:00 hash mark at 2200 rpm and between the first and second hash marks at idle; good ole Shell Rotella 15w-40 (I'm going to buried with 1 gallon containers in each hand).
  10. beno
    beno Injection pump.... argh...... Supporting Vendor Moderator
    20,628
    Media:
    382
    9,922
    Aug 28, 2004
    Atlanta Megalopolis
    I'm running Mobil Delvac 15w40 and at 2000 rpm I am roughly at 2pm as well. At idle it drops down.
    Running M1 5w30 during the winter and the pressure never got above half way up.
    Thinner oil I am assuming based on all of the oil talk on this site.
    Best.
    -onur
    Akron, OH
  11. flintknapper
    flintknapper
    2,658
    103
    May 22, 2004
    Deep East Texas
    This is the same oil I use and my gauge reading is consitent with the above.
  12. robbie
    robbie Guest
    The by pass pressure for the relief is set to max out at 74-75 psi. That does not mean you are at that pressure or beyond. You really need to hook a guage that is accurate up to find out the real pressure. The help you are getting is not accurate. no two stock guages and there reading are the same. You could have a problem, like a pluged up oil filter creating too much pressure or something else, not to say you do. It is best to hook the engine up to either mechancal guage (best in my mind) or a high quailty electrical one to test you oil system to see if their is a problem. later robbie
  13. Heffenoche
    Heffenoche
    517
    1
    Dec 22, 2003
    VA
    For us :banana:+ 1/2 mechanics how and where do you hook up a mechanical oil pressure guage. Mine will occationally read low pressure when at idle (below first hash) but most of the time will be above the first hash at idle. Since it has only done this on two or three in the last year I've chauked it to a malfunctioning guage. I'd just like to be sure
  14. Rich
    Rich
    1,805
    3
    Jun 16, 2003
    One approch is to remove the stock oil pressure sensor and replace with the sensor for the mechanical gauge. The service manual will show where the sensor is, I haven't looked.
  15. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    RH side of the engine block. below the forward exhaust manifold.
  16. Tentsontop
    Tentsontop
    909
    1
    May 15, 2005
    Oil Pressure
    My needle moves higher w/increased RPMs as others have already indicated. It freaked me out a little on my 800 mile test drive home. From what I've been told and read it's more or less normal as long as it isn't pegged in the high position.
