Hello all,
My 88 62 is still giving me a few fits. RIght now, as the engine warms the idle gradually increases. But when I run the A/C, the idle spikes instantly, and remains high even after the A/C is turned off. When I say high, I am talking in the 1100-1300 rpm range. Cranking down the idle screw does nothing to rememdy this.
I am not sure what to start troubleshooting on this. BSVS? I dont know exactly what it does, but I know it somehow affects the idle and timing advance through vacuum pressure - is that right?
Maybe the water temp sender? This is frustrating! Also, I am wondering about the factory timing setting - 8 Btdc. What is the baseline for this setting? What I mean is - what is the nominal or average altitude used to determine this? I live at 1330 ft ASL. Just wondering if I need to do some timing adjustment as well?
If you need me, I will be right here....
Thanks!
Thanks!
