Well Thursday was supposed to be an easy day of rebuilding my 4speed TCase which was pretty much seized. After cleaning the case and the front extension housing thoroughly, I found a crack across one of the ears of the ext housing The PO also had sheared a bolt off in the speedo housing, so the brake backing plate was held on with 3 only. Double There was also duct tape inside one of the tcase to tranny bolt holes (and the bolt was completely loose with an o-Ring in front of the bolt washer. Triple
I'm going to go out on a limb and say this extension housing is long gone? The PO had obviously JB welded the outside crack, but I never noticed due to the seal failures and subsequent oily dirty mess...
Anyways, does anybody have an extension housing and speedo housing that they are willing to part with?
Thanks,
Chris
Thanks,
Chris
