1991 HDJ81 VX automatic.
Took a trip last weekend with trailer in tow to get a vehicle and on the way home the truck started acting up. First it was a random hesitation on the hwy and then once we got off the highway the truck died at the first stop. managed to get it started by putting the accelerator down and got home by driving two-footed as it wanted to die at low rpms/idle. It seems to go okay at speed though with the odd hesitation.
Removed fuel filter, filled new one with diesel purge, primed and started it back up. Same issues. Added 25L of fresh diesel in case I got bad fuel, no change. After this ACSD began to leak out of shaft seal and I figured it was sucking air there. Removed ACSD and installed block off plate. Truck still runs like s***, same as original problem.
Obviously I am hoping it is just sucking air or something else other than the injection pump is needing a rebuild. This is my daily driver and I need some advice on next steps for diagnosis. If I get it started and set the hand throttle it will idle all day at 1200rpm and above. But not below or when put in to gear. Should I run a fuel hose from IP to a jerry can to try and eliminate air leaks in the rest of the system? Fuel hoses with factory spring clamps at filter housing seem a little loose, perhaps I'll put some gear clamps on there to rule them out....
Suggestions needed as I need to get this back on the road.
