grinding noise from rear axle
Discussion in '60-Series Wagons' started by donkeyman, Nov 3, 2007.
  1. donkeyman
    donkeyman
    12
    Nov 3, 2007
    When i slow down and hit the brakes, i get a bad grinding noise. It also grinds when i start from a stop and is worse when i accelerate into a turn. it is not really noticeable at high speed. it seems like it is coming from the rear axle, but i am not sure.
    All the u joints seem ok.
    I drained the gear oil from the axle today, it looked ok. no chunks of metal coming out, the magnet had some gunk on it but nothing unusual. I drained the t case also, it looked ok too.
    I thought it might have been a wheel bearing. Pulled off one of the rear wheels and drum. but did not notice any looseness in the axle shaft. is there a good way to check a rear axle bearing?
    Is it possible that it might be the spider gears?
  2. cruiser88
    cruiser88
    11,876
    Media:
    3
    26
    Feb 21, 2006
    Medford Oregon
    Did you check the pinion flange for slop?
  3. donkeyman
    donkeyman
    12
    Nov 3, 2007
    I did, there didn't seem to be any excessive movement. i have another cruiser and i compared them both, they seemed about the same
  4. donkeyman
    donkeyman
    12
    Nov 3, 2007
    I've pulled the cover from the axle and i am pretty sure that it is not the rear axle, but it is definitely something in the drivetrain. maybe a bearing in the transmission or t case.
    it is just a whirring, gear noise. it gets going real loud and remains in a kind of harmonic effect at about 15 mph. i am starting to notice it at higher speeds, but it is not that loud.
    the transmission and t case shift perfectly and i don't feel it through the shifters so i am thinking and hoping that it is not either of those.
    If anybody out there has had a similiar problem or has any insight as to what it might be, i would greatly appreciate any ideas
    thanks again
  5. Wile E Coyote
    Wile E Coyote Dave's not here! SILVER Star
    3,167
    Media:
    9
    33
    Sep 20, 2005
    Western AZ
    I was able to pinpoint a wasted pinion bearing on the front axle on a Heep I owned several years ago. I just put all 4 wheels up w/ jackstands and let it coast in gear. Since your symptoms appear related to loads, my idea is less than ideal, but if other checks fail, then...?
  6. donkeyman
    donkeyman
    12
    Nov 3, 2007
    if the pinion bearing was going bad, would the seal most likely start leaking?
  7. REKCUT
    REKCUT
    3,386
    Media:
    103
    10
    Jan 5, 2005
    Rogersville, Mo.
    Not to overlook the obvious but have you checked the brake drums? Putting it up on stands and running it should help you pinpoint where the noise is comming from.
  8. DirtyLittleSecret
    DirtyLittleSecret
    1,399
    Sep 21, 2006
    WA
    I agree. When was the last time you adjusted yer brakes?
  9. Wile E Coyote
    3,167
    Media:
    9
    33
    Sep 20, 2005
    Western AZ
    Not necessarily. If left long enough, yes, the extra out-of-roundness on the pinion would def. eventually waste the seal.
    My bearings died due to a deep swim w/ a bad axle vent. Found it AFTER the damage had been done.
  10. donkeyman
    donkeyman
    12
    Nov 3, 2007
    I have pulled the drums. they look ok and are adjusted ok.
    the parking brake actuator levers are stuck, and the parking brake doesn't work. i wouldn't think that could cause this kind of vibration though.
