Gas Gauge...It worked FINE before!
Discussion in '40- & 55-Series Tech' started by Iron_Pig, Aug 30, 2003.
  1. Iron_Pig
    Iron_Pig
    116
    Dec 4, 2002
    Another victim of the 8-month-rebuild. I had the tank reburbished by a reputable shop. It sat for the whole time on the floor of the shop,sealed. It did get wet once on the top, causing the top of the sending unit to get some surface rust. I checked the connections today and they seem fine. I did run out of gas in the yard today so it must not had much in it.I added one or two gallons and it didn't rise the needle a bit.
    Do the sending units go bad just sitting dry in a tank? What should I check next?
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,978
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Have you ever run it dry before and put a couple of gallons in it to see what it read? It may be that there isn't enough fuel in the tank to raise the float.
  3. Iron_Pig
    Iron_Pig
    116
    Dec 4, 2002
    No,Dan. I had it broke down for 6 months before the engine was rebuilt. I just had 68 miles on it when the gas tank leaked which caused me to strip the interior to remove it. That lead to the discovery that there wasn't very much tub left under the rubber mats. That lead to the 8-month tub rebuild which is now complete.Now I'm trying to fix all the aggravating stuff like this gas gauge that worked just fine BEFORE the rebuild. :p
  4. cruiserdan
    20,603
    2,978
    Mar 27, 2003
    Is it possible to pull the sender without dropping the tank? The parts catalog looks like maybe you can't. If you can, you could hook a meter to it and swing the float to see if the resistance changes. Or, I suppose the arm could be stuck. Could the wires have been knocked off when the tank was re-installed? I'm kinda hip-shootin' and thinking out loud so pardon me if you already thought of any of this.
  5. Plowboy
    Plowboy
    798
    Apr 21, 2002
    On a hill overlooking a lake in Idaho
    Is this on a 40? Did you reinstall the ground wire on the sending unit? On a 40 the sending unit can be accessed by removing the passenger seat and pulling out the rubber plug on the tank cover. If you remove the sending unit to test by swinging the float be sure to have it grounded. No reason that sitting for a while should make the sending unit go bad. I would look at the ground wire first.
  6. Iron_Pig
    Iron_Pig
    116
    Dec 4, 2002
    Yeah,it's a FJ40. I'm heading for the wires,for sure.Thanks
  7. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    2 gallons wouldn't raise my gauge above E. I'd fill it up and see what happens.
  8. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    You need more fuel than that to make your gauge move. According to the factory manual the float stops 44mm from the bottom of the tank. Mine needs over 4 gals. to budge the gauge off the E.
  9. Iron_Pig
    Iron_Pig
    116
    Dec 4, 2002
    MAN, you guys are AWESOME !!! :banana: :banana: :banana:
    I added about 4 to 5 gallons of fuel and the needle started moving. Thanks alot...'til next time ;)
