- Thread starter
- #21
Clean off the ABS sensor and re-install it. Torque the bolts to 13 ft-lbs.
I took some extra time on this repack to consider common failures people have experienced after repacking their birfields:
- wheel bearings coming loose
In the past, and on this job today I had to really struggle getting one of my newly repacked wheel bearings to fully seat. When you're putting the disc rotor back on with the new grease seal on the back, it feels like you've solidly thunked it all the way on, but you may not have. I thought I had, but having done this many, many times it did not look quite all the way on and a light went on. I wondered if some are putting the thrust washer and nuts on at this point and then having problems with preload or simply getting the preload even though the assembly has not been pushed fully home. In my case, I was reluctant to grab the rotor and seriously heave on it because I'd degreased the rotors and my hands were greasy. With less experience in this exact situation, I might have continued with assembly and later the bearing would pop on and be loose. I don't know what it is that catches back there but I think it's simply the precise fit of the inner bearing on the spindle. At any rate, feeling suspicious I grabbed a couple fresh rags and really got aggressive with pushing it on. I was rewarded with a thunk and thought I'd bring this to everyone's attention.
So, I'm suggesting that the front wheel bearing installation be amended to include extremely close attention to making sure the rotor is all the way seated before setting up the bearings - up to and including some hammer blows with a brass or plastic hammer to seat it.
Just a couple observations today as I buttoned 'er up.
DougM
I think Landtank's method was the same as mine.
Tighten the inner nut to 45 lbs/ft, rotate, back off and repeat, then just until you feel resistance. Install the lock washer, then torque the outer nut to 45 lbs/ft.
I use a torque wrench for Cruisers because you need to use the socket. It's easy to get carried away with a 1/2 ratchet.
With cars and trailers I use a pair of channel locks. I've found that I get better feel for the pre-load torque.
The rear bearings do require the special alien landing ship tool.
IdahoDoug said:Go super easy on tightening the tiny nuts on the drive plate and cone washers. The torque is in INCH pounds, so easy to break right off.
sleeoffroad said:when installing new drive plates (Most re-use old ones), paint them before installing them. They are not coated when new.
Poriomania said:I'd also mention the periodic check of torque on the steering arm bolts.
photogod said:Step #19 mentions not to get grease on the inner seal. I was under the impression that you should give a thin coat of lube on the seal before closing the assembly, yes? No? Great write up. It sure is nice to see photos of the process. Makes things a lot easier for a wrench like me.
cruiserdan said:The seal lip should get a swipe of grease.
