But did it start and run?View attachment 3516449View attachment 3516450
Another 50+ degree day here so I had an hour to try to finish up the distributor and ballast resistor…here’s a few pictures. This had to be the original ballast resistor as there was no chance of it coming out any way that was normal. After drilling the heads off, I’d chiseled the ballast resistor off, vise-gripped the remains portion of the screws out, re-drilled and tapped new holes. Added a new key switch as well and replaced a jumper from the ammeter.
I love the old iron.To answer your question did it start and run? …….LIKE IT NEVER HAD BEFORE.
I still have the hood off so no fuel tank….and need to replace the starter button on the transmission top cover. I did reconnect the new key switch and ballast resistor and decided to see if there was enough fuel left in that 20” fuel line to even come close to starting…I turned the new key switch on and grounded the starter switch wire and it instantly started.. no choke, no throttle and ran about 1 1/2 minutes then sputtered. It had not run in over 5 months
I couldn't stop grinning. While I should swap the old generator with the new alternator and wiring, it was just so impressive that if this is how it stays, there is not much benefit besides a 12V battery. I can get back in there in the spring. It does turn over a little slowly but started within 1 revolution of the crank…. My only real need for the next 3 months is that IF we get one of those monumental nor’easters with 20+” of snow, I no longer have it in me to shovel and drive up and down the road to pack down snow. Done that for almost 5 decades never having had anything to move snow. Then, we get a warm spell and the packed snow turns to mashed potatoes and no one (like deliveries) can get here. @BILT4ME , I appreciate the gentle push…it motivated me.
But.....where's the TRACTOR in the pic?Today we had around 6” of snow and in the 46 years we have lived here, with the storms of 24” to 32” of snow we have had from nor’easters some years within a week of each other, I decided to plow snow using the Ford 8N. It performed flawlessly did the entire 1/2 mile dirt road and all around the pole barn. Put the tire chains on the rear, without them the mild uphill grades are impossible. Those were a pain and heavy but, they dug right in and finished plowing in about 2 hours
View attachment 3537066View attachment 3537067
I can’t believe you asked …so I went back outside in my pajamas for this picture after a great hot shower
I've pushed and scooped miles of snow on an Oliver and/or Farmall tractors.I can’t believe you asked …so I went back outside in my pajamas for this picture after a great hot shower
