Fender Flare Removal
Discussion in '80-Series Tech' started by alaskacruiser, May 28, 2003.
  1. alaskacruiser
    alaskacruiser
    1,611
    19
    Mar 30, 2003
    LA, CA
    Can someone please post some quick-n-dirty instructions on removing the front and rear fender flares? Do I need to get new seals if I remove them?
  2. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    Oh man you are in for a lot of work.
  3. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    It's easy if you know what to do. Sorry Wrench...
    The rear flares attach with 2 or 3 bolts and a poppy thing (that's the technical term for those who didn't know). You can get to them by removing the rear inside plastic. Just remove all the nuts and pull the flare straight out from the outside.
    The front flares attach inside the fenders and are tougher to get at, but if you persist and don't mind removing the air intake from the fender it should take around an hour total for the fronts. Inside the fender the flare attaches at 3-4 points. Again, just unscrew the nuts and pull it straight out. The toughest nuts to get to are in the back of the front fenders.
    Don't forget to remove all the exterior screws as well.
    I did this awhile back to coat them with line-x, but will likely remove altogether and line-x the lower body if I keep the truck past this summer.
  4. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    Easy - I partially removed both my fronts on Sunday. :flipoff2: :eek: 8) :D
  5. thorvald
    thorvald .......
    1,569
    Media:
    19
    23
    Aug 18, 2002
    on the ice, wyoming
    backing over a rock=1minute easy :D
  6. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    What about just lining them while on the truck?
    -H-
  7. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    The LX450 is different. The flares are integral with bits of the body clading. It may pay to visit with a bodyman before you start.
  8. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I wouldn't want the risk of getting rhino or line-x on the paint, even with tape, and I would think it would be harder to get them completely clean inside and out. Now if it was a beater edition.......
    you should just rhino the whole truck! 8)
  9. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    I took mine off to spray them originally, then several months later touched them up with another 2 coats while on the truck... you just can't get as good coverage without full access to them.  And unless you tape like crazy to prevent overspray you can't get far enough away to get a nice texture. The last few coats work great at about 18 inches.
  10. BMT
    BMT
    325
    Apr 1, 2003
    I have to side with Junk. I tree...10 seconds...no effort...the look on your friends faces...priceless. In theory with turn around time you could be done in under 5 minutes. Of course you still may need that bodyman.
