exhaust routing
Discussion in '40- & 55-Series Tech' started by cavsfj40, May 4, 2003.
  1. cavsfj40
    cavsfj40
    194
    Apr 16, 2003
    My cruiser has the exhaust coming out of the back and i am wondering if this is the stock location. I have seen a lot of cruisers with a tailpipe poking out of the side in front of the drivers rear tire. Last summer i got terrible exhaust fumes from the air swirling back up in with the top off and i am thinking that re-routing it out the side would help correct this. If it does go out the side, where does it cross the frame?
  2. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    In my '71, the stock exhaust follows the inside of the frame to the muffler, which is along the inside of the frame parallel to the driver"s side rear wheel. The tailpipe makes an "L" and comes out just behind the driver's side rear wheel. This was the case for '58 through '74. From '75 on, the stock exhaust pipe goes back to just behind the driver's wheel, then makes an "L" to the right. The muffler attaches perpendicular to the rear wheels in the center, and the tailpipe exits just behind the passenger side rear wheel. Here's a page of diagrams from the SOR catalog, which takes its figures from the various Toyota body and chassis manuals: http://www.sor.com/sor/cat046.tam?xax=76&page.ctx=cat046.tam
  3. 74cruiser
    74cruiser
    44
    Aug 28, 2002
    .i have a 74 w/ 2f enigine and my exhust goes out the back on the drivers side. there are no "L" pipes in it anywhere, its just straightfrom the engine to the muffler to the tail pipe
  4. cavsfj40
    cavsfj40
    194
    Apr 16, 2003
    I am looking to run the exhaust pipe uot the side to help get it out of the way and hopefully to help the fumes. Any suggestions on how to get it out in front of the tire?
  5. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    I would go out behind the driver side rear tire, if you go out in front of the rear tire wouldn't it force you to run the pipe below the frame? Not near my cruiser now, but I will go check it out this afternoon.
  6. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    I agree with Cruisin' Bailey. You want it just behind the driver's rear wheel. I would just get the angled tailpipe and run it in the stock position. You want the tip of the pipe to stick out about 2 inches beyond the rear panel so the hot exhaust won't blister your paint. SOR and MAF I am sure would be happy to sell you one of theirs. (I have a used one myself that is a little bent, but if you want it for really cheap let me know.) You would have to cut off the old tailpipe and get some sort of sleeve to put it on the back of your muffler. Then, there is a little ubolt hanger thing that clamps it to the frame.
  7. pvaman
    pvaman
    129
    Apr 11, 2003
    one thing to consider, if you're getting a lot of exhaust up front it *could* be a leak at your exhaust manifold gasket. Mine is leaking and i can definately tell.
  8. cavsfj40
    cavsfj40
    194
    Apr 16, 2003
    I am pretty sure the manifod gasket is good and it only does it with the top off. never once with the windows down and the kick vents open.
  9. Plowboy
    Plowboy
    798
    Apr 21, 2002
    On a hill overlooking a lake in Idaho
    you get exhaust sucked back into your cruiser, because of the vacuum created as the cruiser is moving. Same principal nascar uses in drafting. Running exhaust pipes out the back or side doesn't really matter in solving the exhaust being drawn back into the tub. If you are really serious about not getting the fumes, you need to install an airfoil on the back. Remember seeing station wagons with the airfoil over the back window? It breaks up the air flow at the rear of the vehicle to cut down on the vacuum effect, that way the rear window stayed clean. An air dam under the cruiser does the same thing, until you go over the first rock. :p
  10. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Mine goes out the side behind drivers side tire, stops even with the body, never had any fume vacuum problem at all, I have my top off 8 months a year.
  11. Trev
    Trev
    57
    Feb 24, 2003
    Keizer, OR
    It is possible to route the exhaust above the frame rail with an exit in front of rear tire. My 40 has been this way for several years. The muffler is between the frame rail and the transmission. The tail pipe runs above the center crossmember out over the frame rail and down. It is a little bit loud however.
  12. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    Remember seeing station wagons with the airfoil over the back window? It breaks up the air flow at the rear of the vehicle to cut down on the vacuum effect, that way the rear window stayed clean. An air dam under the cruiser does the same thing, until you go over the first rock.  :p[/quote]
    80 series have the airfoil on the back and it works great for keeping the rear window clean. It would look incredibly stupid on a topless 40 series though. :D My truck is pouting over the comparison to a station wagon.
    I have had great success with rerouting the exhaust to the side with just an angled tip. A buddy had a CJ-5 and a CJ-7. The 5 was so bad you couldn't ride in it. He couldn't figure out the difference until I pointed out the exit point in the exhaust. A couple of bucks later he was stylin'. A least as stylin as you can be in a Heep.
  13. Guest
    Guest Guest
    My farthers FZJ80R does not have a thingy on the rear window, And I have never seen one on any 80 Series. ???
  14. Gumby
    11,781
    310
    Dec 13, 2002
    Now you have :D
