Engine died from freeway speed in "N"
Discussion in '40- & 55-Series Tech' started by Lor, Aug 22, 2003.
  1. Lor
    Lor
    127
    15
    Mar 5, 2003
    Seattle, WA
    I've just noticed the other day when I was exiting at a ramp and shifting to N. The engine died. It did that twice. It is ok in the city. What is the cause?
    1. F engine with aftermarket carb
    2. New plugs & wires (8mm Accel)
    3. 650-700 rpm idle
  2. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Lets just try to get some details straight:
    So you were coasting, with the clutch fully depressed, foot off the gas, moving shifter to N?
    By "it did that twice" do you mean in two seperate instances of exiting the highway or what?
    I assume that it otherwise idles normally?
    Any stuttering, loss of power while driving at freeway speeds?
    Oil pressure problems? (mine has oil pressure problems when moving to idle RPM's from highway RPM's.
  3. Lor
    Lor
    127
    15
    Mar 5, 2003
    Seattle, WA
    Yes
    Yes, two separate instances.
    Yes
    No
    I don't know. The gage is dead.
  4. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    [quote author=Lor link=board=1;threadid=4547;start=msg34239#msg34239 date=1061595679]
    [/quote]
    Or maybe you do have some very serious oil pressure problems? :D ;)
    Really the only suggestion I have is to fix your oil pressure guage and see if anything funky is happening there.
    You indicate that nothing at all else is the matter with the way it runs, any little anything may make this much easier to diagnose.
    Anything particurly similar about the two instances? Close in time, or spread apart?
