All of my other windows work from the main panel except my ds. I removed it and unplugged and still no workie, thoughts?
Thanks, will try this tomorrow!May be carbon buit up inside the switches. Many toyota's have same setup. You should be able to open up the switch and clean the contact points with a sand paper. See the attached picture (not from the cruiser but from a camry). You can see the copper contacts. Just make sure to slowly lift the housing off the main unit and clean the contact points. The Drivers door is AUTO so you will see couple of plates with contact points. Insert a folded sand paper and clean it. Make sure to have the window lock button pressed in during the removal. If not, the window lock switch base can come out and then you have to deal with a tiny spring inside.
