1997 FZJ80 with 3 inch icon lift springs, caster correction bushings, 2 inch drop brackets, 285/75 16 ko2s.
I started out with the icon 3 inch kit with the supplied caster bushings. At that point there were no noise on the driveshaft. Steering was bad though and i thought the bushings did not give me enough caster. So i ordered 2 inch MAF drop brackets and retained the caster bushings. It did correct my steering but it developed driveline noise. Pulled the front driveshaft out then the noise is gone. After reading a bunch of threads, I am convinced that i dont need a double cardan shaft. I just need to correct my angles.
So my question is, If i remove the caster bushings and replace with oem bushings and replace my 2 inch drop brackets with 3 inch drop brackets, Would it correct my driveline angles? At least theoretically? And if I am correct in assuming that, Will my stock driveshaft length be ok with the 3 inch lift? Meaning, would it cause noise due to being stretched out because of the 3 inch lift? Thanks.
