cluch problems
Discussion in '40- & 55-Series Tech' started by wayne_fj40, Feb 25, 2003.
  1. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    yes I have put my engine in and out 3 times in the past couple of days.Ive just about had it!!anyway my clutch will not disengage Ive tried everything list of crap
    chev v8
    toyota three speed and aftermarket overdrive
    new clutch pack
    11 inch flywheel
    made spacer plate for in between bell and gear box
    roughly between 1/2 inch and 5/8 of inch thick
    throwout bearing fully disengages
    engine is on ground with bell on and when I pull back the clutch arm I should be able to spin the pilot tool with my hand and cannot so I'm not sure what is wrong any ideas anyone before I blow the fu**** up ??? ??? ??? ???
  2. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    is the disc installed backwards? common mistake....
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    No the flat side is at the flywheel unless that is backwards but not on any thing else
  4. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    woody what brand clutch are you running? Iv'e been told if run centerforce I will not have this problem but I don't buy It because It still should release sitting on the ground thats all chevy
  5. woody
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    mine is a LUK brand....when I had the 350, advance bellhousing, and toyota stock 4-speed I ran a Centerforce.
    So long as it's a diaphram clutch and not a 3-finger jobbie, you should not have problems.
    the key is to find out what's hitting and where....and only some time/inspection work will find that.
  6. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    yes It Is a diapram style I've got a nother tranny I'm going to bolt to It tonight maybe then I can better see whats going on I've got few places around here who specilize in landcruiser conversions
  7. theo
    theo
    1,432
    Feb 19, 2002
    I put my pilot bushing in backwards the first time. Then, while bolting up the tranny, I gouged the bushing with the tranny input shaft and jammed some bronze bits onto the bearing surface. That caused the tranny to drag with the engine and it felt like the clutch wasn't disengaging.
    After fixing that I still had trouble with the clutch and finally solved it by pulling the slave cylinder and holding it right-side-up while bleeding to get the last traces of air out. Still, my clutch felt sticky for quite a few miles until it broke in some.
    Stock engine, bell housing, throwout bearing, throwout fork, and finger-style clutch from '69 C30. Works fine now.
  8. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Well thanks Theo things to think about as I look atit again and of course thanks wood
    But If anyone else has any ideas let me know I'm game to hear them all
  9. theo
    theo
    1,432
    Feb 19, 2002
    I emailed you a picture of 2 types of GM release forks. Just tossing ideas around. There may be a difference between them as far as leverage (travel distance).
