Can you identify this limited slip?
Discussion in '40- & 55-Series Tech' started by cmilliron, Jan 26, 2003.
  1. cmilliron
    cmilliron
    39
    Nov 3, 2002
    Here is a photo of my FJ40 limited slip differentials (F/R).  I'm going to replace both with ARB Lockers, but would still like to find out what Brand-Model they are and what parts may be available....
    Cliff
    Lodi, CA
  2. Pin_Head
    Pin_Head
    13,735
    1,299
    Feb 6, 2002
    OC, CA
    It looks like a GM gov lock to me, but I have never seen one intact; only busted all to pieces.
  3. rocrawler
    rocrawler
    69
    Sep 11, 2002
    I found one exactly like that in a '70 FJ40 parts rig that I bought ???
  4. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    That definately looks like a GM Gov Lok. POS IMO
  5. woody
    woody Internet Fireman Staff Member
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    From memory (vague), the GM Gov Lock was a near drop-in for Cruiser diffs....IIRC, there was some minor machining of the ring gear seating diameter required to bolt it up, and perhaps some machining of the side gear bearings.
    Common mod in the "early days" when there wasn't a plethora of Detroits, EZ-Locks, ARB's, etc available to purchase.
    (heh heh - I used "plethora" in a sentence - heh heh)
  6. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Woody, you want a cookie?
  7. Pin_Head
    Pin_Head
    13,735
    1,299
    Feb 6, 2002
    OC, CA
    The gov lock is a cool idea, but they don't last long with big tires. The work as a LSD until the side gear slip gets to a certain speed and then it locks up. This sudden lockup along with the inertia of big tires results in BANG-POP. Fortunately the cracked carrier in my Suburban tow rig held together long enough to get home where it grenaded just backing out of my driveway. The spider gear shaft was sticking through the cover and it looked like the rear end was smoking a cigar. :eek:
    If you don't have tires bigger than 33s and you go easy on the skinny pedal I say run them until they break. Might be good to carry a spare 3rd member on the trail.
  8. PHAT MAX
    PHAT MAX
    434
    Jan 30, 2002
    if he dont want it I'll take it! :D
  9. cmilliron
    cmilliron
    39
    Nov 3, 2002
    Okay,
    you guys are definitely on to something....
    I dismantled the 3rd member (after checking R&P mesh patterns, which were excellent).... here's what I found:
    The Lmited Slip carrier had the bolts holes enlarged and shifted slightly inward, to allow the carrier holes to line up with the ring gear holes.
    There were also shim plates about 1/4" thick between the carrier and the ring gear (I'm assuming to allow the R&P to mesh such that the bearing preload nuts would be adjusted to approximatly the same depth)....
    Sure looks to me like this Limited Slip carrier belongs to something other than a toyota...
    I did not press the bearings off the carrier as it is going to be a big paper weight....
    The outter races are Koyo 17831-N... Is this the stock Toyota bearing?
    What bearings would you suggest to buy...???
    Cliff
    Lodi, CA
  10. woody
    10,331
    Media:
    303
    1,086
    Jan 15, 2002
    Toquerville UT
    if you are reinstalling, just replace what's there. It was a common swap in the 70's, and if it's been working for this long, don't mess with what the PO did.
    Not sure if that's the stock bearing or not...any bearing house can supply ya tho.
  11. cmilliron
    cmilliron
    39
    Nov 3, 2002
    Both Limited Slips are broken.... and the ARB's will be here tomorrow....
    Just thought you guys might have a personal preference on bearing manufacturer....
  12. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Timkin bearing is one of the best know, and well respected bearing manufacturers in the world for good reason. I'm not sure if they make the correct bearing, but I doubt they don't.
    My recommendation for bearings is to ask ARB what they recommend for use with their unit. Should help with any warranty issues that may come up.
  13. rusty40
    rusty40
    91
    Mar 6, 2002
    SKF bearings are good aswell
  14. cmilliron
    cmilliron
    39
    Nov 3, 2002
    Okay this wraps up this Magical Mystery Tour (BTW, I vaugely remember the real Sgt Pepper's Lonely Hearts Club Band.... anything to be 16 again...!!!)
    ARB says Timken or Koyo...
    So Timken it is, $28 a piece....
    The End
