brake pedel stick to the floor...
Discussion in '40- & 55-Series Tech' started by rusmannx, Jun 3, 2003.
  1. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    well, not quite to the floor. when i push the pedal i then have to hook it with the toe of my shoe, or reach down and pull it back up with my hand.
    it has stuck like this for a while... any thoughts?
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    is the return spring missing?? This might also be the cause of your pressure problem.
  3. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    i thought someone would ask that.
    no, i replaced it with a new one from sor.
  4. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Sounds like something up top (booster, master) is fawking up pretty bad. I doubt your pressure problem and this are not related. Sounds like you are a good candidate for a new booster/master. Or at least take some stuff apart and see whats goin on. Oh yeah, if you pull the pedal up, does it relieve the pressure on the wheels that are locking up?
  5. rusmannx
    rusmannx
    1,159
    13
    Feb 9, 2002
    HIT IT!
    no, each time i pull the pedel up i can then depress it (an inch is all it ever moves) and over time (a day of wheeling) the front tire will inevidibly start to lock up. then i get out and crach the bleeder valve to relieve the pressure again.
    i would like to find out if all of this is bad plumbing/dirty master.
