Not my creation, got it with a trailer I just bought, but interesting I think in that the majority of it could be done easily enough by a DIY with access to a welder. Good potential for improvisation in other configs too and hopefully may give you some useful ideas.
Pros: easily built with a welder and (almost) all readily available bits and pieces. Not clanking like a lunette as there is no slop anywhere (and even has 2 bushings in the central "bone" u-joint for vibrations and stress reductions). Easily disassembled for anti-theft prevention (I replaced the bolts with hitch pins). As strong as you want to make it, just use bigger components, it can be easily scaled up.
The bent lunette stem allows for 2 set heights.
the whole assembly can be replaced by a regular military lunette ring coupler as needed since the female tapered coupler is built-in
Cons:
need to source a swiveling bent lunette and mating female receiver. Former relatively easy to get, latter less so.
more complicated than a regular lunette ring coupler
Description of DIY components from left to right:
- 2" tube to insert in truck receiver.
- DIY "bone" U-joint (a cute DIY part IMO)
- coupling welded on the stem of a military 105 ring coupler with lunette ring cut off
- female 105 (I think) receptacle welded to 2" tube
- 2" tube tongue
As mentioned the neat part is that it was made from readily available pieces (except for the lunette stem receiver):
the Us are made from 3-sided sections of a 2" ID square tube welded sideways to a 2" OD square tube.
The bone is made from 2 pieces of 2" OD circular tube (with poly bushings pressed inside) welded at 90deg on a 2" OD square tube.
the RHS U is similar to LHS but the 2" OD tube section is welded on the stem of a 105 ring coupler.
Pretty cleverly done in a DIY way I think.
Cons:
- 2" tube tongue
