- Thread starter
- #201
On post #196 pic #4.
Take care of them wires or they will get cut after a few hundred miles... ( im sure you will but just saying).
On your plumbing for the modded tank.. You need to to have the GM canister above the tank highest point level... Your vent solenoid can be near the canister or engine.... I put it on the engine the second time around as it got clogged with dust the first time I put it under the frame.
You can do away with the fuel vapor separator and cap off all the nipples on the plate that is under the frame, except for one (the thickest hose) that continues to be used as a breather for the filler neck...
On the tank you will need one nipple for the breather, one nipple for the fuel pump... Your pump should have 3 fittings One for fuel, one for canister and one for tank.
I think I got it right......
Yes I will wrap those wires.... still tidying up the wiring :whoops:
Manu... you're spot on as usual!!!! It so nice to have someone knowledgeable about this exact swap!!
What did you use to cap the nipples in the tank and on the the plate?
Also, is regular fuel grade hose acceptable for all the EVAP lines? I notice GM use like a poly/plastic type line... fuel hose is vapor tight though right???
GM pump has three fittings... 1) fuel supply 2) fuel return 3) EVAP
