jestlurnin
1. The oil pressure sending unit on the engine I'm swapping in, the 78' is under the oil filter on the wrong side of the engine from where the wiring is in the 45 for the oil pressure ending unit. There appears to be a hole in the correct side of the block that will however accommodate the oil pressure sending unit on the other side of the engine so that I won't have to monkey around with the extending the wiring etc. Can someone definitively tell me if this hole will in fact accommodate the oil pressure sending unit? It seems to thread in but I was under the impression that the oil pressure sending unit would actually have to come into contact with the oil which would make no sense as this hole was "empty" and there are no signs that oil was flowing out of this hole at any time. Would make sense that everything is interchangeable on the blocks o accommodate RHD and LHD vehicles and the different wiring. Maybe I don't understand how the oil pressure sending units work??...
Please see pictures below. 1st one is oil pressure sending unit on the 75' engine. 2nd picture is where I think it goes on the 78' engine after I removed it and 3rd picture is of where the current sending unit sits on the 78' under the oil filter.
Thanks for the help!!
