I have the "classic" rear 4plus bumper on my 60. One of the swing arms is a little bit stiff to move. How do I lubricate the pivot? I can't see how to un-assemble it.
I don't have one (wish I did), but don't those have oil-impregnated bronze bushing ? If yes, I'd just squirt some light machine oil, like 3-in-1 and let is soak until you can get it apart and grease it. IIRC, isn't there a collar with a set-screw that holds the pivot on ?
A, This is correct. Dave and I use the impregnated bronze bushings. 3 in 1 oil is all that is needed, HOWEVER, NO GREASE! Yes, a shaft set collar holds the assembly down and to the spindle.
If trash has built up inside the collar (I doubt this is the case, pretty tight tolerances) take a Scotch-Brite/ SOS kitchen pad and scrub the I.D. of the collar and then add the 3 in 1 before installing.
J
So, uh...why no grease? What happens if you used grease?
Asking for "a friend" *ahem*
Tight tollerances he said
So if someone were to have greased theirs, it would just be a matter of thoroughly cleaning it and applying some 3-in-1 oil before reassembly as long as no damage has been done yet?
Note: I haven't done this. I don't even have one to do it on![]()
^^ I did.. guess... I gotz to pop them swingers out !!!
Yes. You'll have to remove the collar to get the arm off. Seems like several posters have drilled/tapped the pivot and installed a grease fitting to avoid having to take it off. I didn't do that (short on time, tools, and knowledge) when I installed my 4+ bumper earlier this year. That would, however, be a good project for next year.
I removed the set screw but the collar seems to be wedged on tight, I couldn't remove it. I'll try squirting a little light oil through the set screw hole and see if that helps.
