Hey guys,
I have a 1990 toyota Pickup. 3VZ-E. 174,000 miles. A few months ago the truck would start to lose power when I put a load on the motor. You don't really notice in first and second gear because those don't really put that huge of a load on. In neutral the truck will rev just fine, when I try to get passed 3000 RPM in third (40-45 MPH) is when I really notice it. The truck loses power. My pedal will be to the floor and it will slowly but surely reach about 50 MPH TOP SPEED. After I let off the throttle, the truck will die.
Things I've done.
- replaced timing belt
- replaced water pump (mine as well since I'm there)
- replaced fuel filter
- checked to make sure fuel pump works (it does)
- checked for a vacuum leak (there is not one)
Next steps:
- the truck will start, but I do feel less pressure from the exhaust and it appears to be smelling like sulfur. Im going to take off the Catalytic converter to see if the issue persists.
While that is happening, any other thoughts?
Things I've done.
Next steps:
