2f power? is it possible?
Discussion in '40- & 55-Series Tech' started by snelson, Sep 2, 2003.
  1. snelson
    snelson
    70
    Sep 8, 2002
    ok here is the scoop, i've got a 82 fj60 with a 2f that has a lot of miles 192k is there any hope? ??? this past weekend i pulled some waverunners to a local lake i dont think i did over 55 other than going down hill and i wont even comment on the up hill part of it, i guess my question to all of you is how can i get more power out of my 2f? it has a weber 32/36 and 31 10/50's and i really don't care about the towing end of it because i hardly ever tow but even on the highway it is not all that great. how about advancing the timing or somthing like that. i hear a few people say that there 2f runs strong with a lot of power but i am not seeing it in mine, anyway thanks for the help.
  2. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    I'd start with a compression check. You don't say what the oil pressure is, but of it is low, with that many miles and the previous maintainance unknown, the bearings may be excessively worn. You really don't want to try to horse up a worn out engine. There are a couple of ways to see if poor compression is rings or valves, you need to determine that. If everything is ok up to this point, the biggest gain in power I got was from a HEI and a carb rebuild. Header will help.
    OK I'm done, now you V8 guys jump in.
    Degnol ;)
  3. fsusteve
    fsusteve
    3,802
    Media:
    18
    49
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    What he said and maybe run the bigger weber. It's a 5000 lbs. truck being pushed by a tractor engine. ::)
  4. snelson
    snelson
    70
    Sep 8, 2002
    will have to try the compression check and go from there. thanks for the advice so far. i havent put a gauge on the block itself for the oil pressure but the gauge in the cab stays just above low point in the middle if that makes sense. i am sure the motor is getting tired though but i guess i was just hoping for a miracle cure.
  5. Slowerthanu
    Slowerthanu SILVER Star
    1,326
    8
    Apr 23, 2002
    Bountiful, Utah
    Get ri of the WEBER, I have a 38mm model and I hate it (I do a lot of rock crawling though and it sucks at angles)
    Your distributor is fine, it is the well waterproofed electronic model so I would not touch it.
    Think about a header and a rebuild, mill the head for some more compression (after rebuilding) and put a better cam in (I have heard good things about Man-I-payalots cams).
    I just rebuilt my head on my 213,000 mile 2F (No milling though) and noticed a differance in power idle and mileage.
  6. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    I reread my post and it is somewhat confusing. If you have low compression, it could be as simple as a valve job to bring it back up to snuff. If, on the otherhand the compression rings or cylinders are worn, a valve job won't help it.
    For lowend torque, you can't beat the stock Aisan Carb, or the 32/36 webber. The 38/38 is better for high rpm as it will dump more gas. I've not known or heard of many people who have got the 38/38 to perform well overall.
    Get the basics checked out, then go to the tune-up basics.
    I've got a '40 with the '74 F1/2 engine and my oil pressure gauge is always pegged on high, but, as I hear, they are not reliable. I'm installing an oilfilter mount that has the receptacle
    for a mechanical op gauge, just to check.
    It is a tractor motor, but capable of a reasonable amount of power.
    Oh, you might check to see if your secondary is opening properly.
    GL
    Ed :)
  7. snelson
    snelson
    70
    Sep 8, 2002
    thanks for all of the input at least it will steer me in the right direction.
