Specifications
Engine
Engine Type223cc air-cooled single-cylinder four-strokeBore And Stroke65.5 x 66.2 mmCompression Ratio9.0:1Valve TrainSOHC; two valveInduction30mm CV carburetorIgnitionCD
Drive Train
TransmissionSix-speedFinal Drive#520 O-ring-sealed chain; 13T/50T
Chassis / Suspension / Brakes
Front Suspension37mm leading-axle Showa® fork; 9.0 inches of travelRear SuspensionPro-link Showa® single shock with adjustable spring preload; 6.3 inches of travelFront BrakeSingle 240 mm discRear Brake220 mm discFront Tire2.75-21 Rear Tire120/80-18
Rake26.83 degreesTrail103mm (4.0 inches)Wheelbase52.75 inchesSeat Height31.9 inchesCurb Weight267 lbs (*Includes all standard equipment, required fluids and full tank of fuel-ready to ride)Fuel Capacity2.3 gallons, including 0.7 gallon reserveGround Clearance9.5 inches
Other
Available ColorsBlackModel IdCRF230MEmissionsMeets current CARB and EPA standards
Factory Warranty Information
One YearCoverage of defects in materials and workmanship
Opinions on this ride as a commuter and longer touring ride performance.
Thanks....
