For Sale 1997 80 series in Tucson
***SOLD***
As much as I've enjoyed my 80, it's time to make a change.
1997 Toyota Land Cruiser
Dark green with gray leather
240k miles
Factory lockers
Engine freshly rebuilt (over $3K in parts and machining) I've probably put 500+ miles on it since the rebuild.
Head:
Head surfaced, valves ground, 3 angle valve seats
valves adjusted, new timing chain, gears, tensioner and guides.
All gaskets replaced (there was no head gasket issue, the timing chain
had jumped two teeth), new head bolts
new Denso plug wires, Denso Iridium spark plugs, cap & rotor
Block:
main and rod bearings inspected and reinstalled (they looked like new)
crosshatch still visible on all cylinder walls, pistons cleaned and reinstalled
new motor mounts, alternator brushes and starter contacts replaced,
knock sensors replaced with OEM, coolant temp sensor replaced,
new exhaust studs and nuts, all head bolts replaced with new,
Cooling System:
PHH replaced with silicone hose and
constant torque clamps, new thermostat, Toyota belts, fresh Toyota red antifreeze
new heater valve, new Aisin water pump, Eaton fan clutch drained and
refilled with 20k cst fluid, all new radiator hoses,
Radiator replaced Aug ’12
Fuel System:
Injectors cleaned, new o-rings and flow tested.
Intake manifold cleaned,
Fuel pump replaced Oct ’12 with new Denso
Emission system:
New charcoal canister in Mar ’12 (GM alternate)
O2 sensors replaced Sept ’12 (Denso)
vacuum switching valve replaced and relocated,
new breather hoses, new Thermostatic vacuum valve
Suspension/steering:
OME “stock height” lift with Tokico shocks less than 10k since installed
10mm spring spacers, new steering stabilizer, all power steering hoses replaced
and pump re-sealed.
Powder coated satin black wheels with 285/75-16 Nitto Terra Grappler tires (less than 10k miles)
Alignment done at time of tire installation
Brakes:
Brake Performance slotted rotors and ceramic pads on all 4 corners (100 series pads up front)
Alas these expensive rotors have slightly warped, slight pedal pulsation when stopping,
but I have the stock Toyota rotors turned and ready to go back on. Brake fluid has been replaced with fresh Dot 4
Brake booster replaced June ’14 along with the vacuum hose and check valve for the booster
Transmission:
All lines replaced, fluid replaced with synthetic and front pump seal replaced
HVAC:
New compressor and drier (Denso) and drier relocated to battery box
using modified factory R12 lines, condenser and hoses/lines flushed,
all 3 schrader valves replaced, A/C and heat both work great!
heater hoses in engine compartment replaced,
Exterior:
No rust! An Arizona and Texas car it's whole life
HIR hi and low beam headlights
55w driving lights built into front bumper
custom front and rear bumpers (with swing-out and 2” receiver) by Tommy Gunn Fabrication
Hood struts replaced Feb ’13, rear hatch struts
Interior:
Pioneer Avic Z2 cd/dvd/am/fm/Ipod/bluetooth/navigation/backup camera ($1200 new)
has updated maps and upgraded 40 gig HD (will store 100’s of cd’s)
Pioneer 6” front speakers and 4” rear door speakers
LED dome lights, turn signal bulbs and 7w.cree back-up bulbs(one is out)
ScangaugeII included
Leather is good on the 2nd row and like new on the 3rd row. The fronts have fitted seat covers, which are in excellent shape.
Seat gears replaced in drivers seat, passenger seat currently not moving fore/aft
Needing attention:
Paint is fading on hood and roof
Tailpipe rattles, primarily at idle
Fog light switch lights, but doesn’t send power to the relay
One of the 7w Cree back-up lights is out
No passenger side floor mat and the drivers side is worn
Trip odometer works intermittently
Passenger side running board is dented
Woodgrain on dash is faded and some is missing where I started removing it
Console lid needs to be recovered
Passenger seat belt needs help retracting
Black plastic trim along the bottom of the side windows is cracked and missing in spots
A couple cracks in the dash, although not noticeable with the dashmat
Extras included:
Scangauge II
Extra hoses and belts (used but in good shape)
10 oil drain plug washers, extra spark plugs, wires
Factory manual, 3rd row seats, stock roof rack
Misc engine senders, fuel pressure regulator
$8500 OBO
PM, cell 520-982-2533(I can't take calls at work, so leave a message and I'll call you back),
email: rexscofield@cox.net
More pictures here: https://flic.kr/s/aHskaLqWKS
great looking truck. nicely set up. GLWS
Bump for a really nice 80. Do you have any contact info for the guy that did the bumpers? I've been looking and I like yours better than any I've seen. Good luck, I'm sure this one will go fast
Thanks!
Tommy Gort of Tommy Gunn Fabrication in Phoenix did the bumpers. He can build pretty much any design you'd like. For my front bumper, I sent him pictures of four different bumpers and said I'd like this part of this bumper, this part of this one, etc then he drew up a design and sent it to me and we changed a few details and he did the fab (1/4" plate). The price was very fair. His number is 480-200-0543 or email tpgort@yahoo.com
Awesome! Thank you, sir
Best deal I've seen in a long time. GL!
Can this run another 150k miles ?
I haven't had chance to post on here, but I had a verbal agreement with the seller along with a flight booked (non refundable) to pick the Land Cruiser up , and he sold it anyway. My fault for not putting deposit down , but I figured booking a flight was sufficient.
In the future buy local or put deposit down I suppose.
Thanks for not putting a deposit down, this thing is awesome!
Rex (the seller) is a great guy him and his wife were very welcoming and had meticulous documentation.
