- Location
- United States
original low kms 2f, 4 speed
sandblasted most all parts
new rear u joint
new rear shackles
new belt
new front glass
rad flush n pressure tested then painted
all fluids flushed, axles, rad, tranny, transfer, engine, steering box
new steering box oil seal
original seats. tears under cover, all foam still great, back of seats are in great shape
all hardware on fj45 were swapped out to stainless, all hose clamps, all hoses
5 original tires/16 inch re painted/blasted rims
new master brake cylinder
including another windshield painted dune beige as its in better shape than the 1 on truck
including another rear axle as I was gonna swap some parts over when I have some free time
original doors are included, need primer/paint
box has 75 % new steel, most hooks replaced, front brace replaced, bottom braces replaced
tailgate is original n fits nice n tight( no rattles ), original chains work perfect
hardtop/roof are both included, in good shape, need some body work. paint/prime, all glass/gasket is perfect
wipers work well, oem wipers
paint is dune beige nason, soso paint job. used a great strong expensive Nason product, code 416 Dune Beige, epoxy primed. Just didnt have as much time into finsihing it perfectly
headache rack is original and is perfect
front lights are recently new
the fuel tank is recently new
engine bay is spotless!
harness cleaned up and properly rerouted after painting
original full floating 1 ton rear axle(original suspension brace included)
new manifold gasket to first down pipe
removed broken stud from manifold, lubed and cleaned all 3 at same time so they do seize/break like the always do
new stainless wheels nuts x24
original radio, have not re installed new antenna
purchased a few months ago in neglected state and had some spare time n favors owed. I have ran out of time and leave for my destination within 30days or so. Hence the reason I didnt do museum quality paint, its a cruser and looks good for being 32 yrs young, didnt finish the roof/top/doors.
The engine does not leak any fluids and purrs like it should, starts right up first turn
the original manual is included, original keys included
still need front shackle bushings
trying to get a new ignitor to match my dizzy
needs new windshield washer bottle
I have old cracked signals, but wanted a new set. hence y there is none shown
have all emblems but 1 landcruiser badge on side apron
planning on painting white TOYOTA lettering on tailgate
original BC truck
title in hand, no liens, in my name
to sum it all up, this is as far as I have got on this build. I hope to see some1 enjoy my hard work and finish it 100% down the rd as it should
$16000
604 9058062
or email at jordanrich@hotmail.com
new rear u joint
new rear shackles
new belt
new front glass
original BC truck
$16000
604 9058062
